Voxel Custom firmware build for Orbi RBK50/RBK53 (RBR50, RBS50) v. 9.2.5.2.14SF-HW
@Gregger96 :
You speak of NETGEAR versions 2.7.2.104 and 2.7.3.22. You also mentioned you "reverted to stock". For Voxel's 9.2.5.2.X builds you have to downgrade to NETGEAR 2.5.2.4 first; then, you can drop Voxel 9.2.5.2.X on. Just validating that you have done this.
I am using 9.2.5.2.14 and I have video calls that last several hours without interruption. I have 2 satellites, one is wired to the router, the other is wireless backhaul to the router.
Yes I did drop to NETGEAR 2.5.2.4 first to avoid the soft brick.
I have recently tried it twice but every time I change the firmware to V9.2.5.2.14SF-HW on the RBK50 the circle filtering stops working.
I have 3 x RBS50 and 1 x RBR50
I downgraded the RBS50's to stock firmware using RBS50-V2.5.2.4.img
I downgraded the RBR50 to stock firmware using RBR50-V2.5.2.4.img
I checked the circle app and the filtering started working. I then upgraded the RBS50's to Voxel's firmware using RBS50-V9.2.5.2.14SF-HW.img. Then upgraded the RBR50 using RBR50-V9.2.5.2.14SF-HW.img. Now when I checked circle app, I can see the router firmware version showing as V9.2.5.2.14SF-HW. So in know that circle can see the router. When i check the history of any device, it last updated when the stock firmware was loaded.
Any pointers of help on this please? Much Appreciated
>Since they auto upgraded to 2.7.3.22 I had major issues with my wired satellite dropping connection to the router and restarting every 10-20 minutes.
>I decided enough was enough and switched to voxel's firmware. Problem was the issue still persists on 9.2.5.2.14SF-HW.
I also experienced this exact scenario, with 2.7.3.22, as well as 9.2.5.2.14SF-HW and 9.2.5.2.15F-HW(I'm quoting here because that's where the situation is brought up). One or two drops per hour, didn't matter if I was wired or wireless. I switched to 9.2.5.2.13SF-HW a couple days ago and have had no issues since.
Having the same issue but with version v. 9.2.5.2.15SF-HW. Circle is not filtering. Any ideas?
