Voxel
Part of the Furniture
Forgive a beginner in architecture, but what is this good for?![]()
It is good for R7800, R7500, R7500v2 (IPQ806x)
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
Voxel.
Did you create you own authorized_keys file? this can be done with Puttygen
you need to do this and add it to the stick also.
DIR of stick should have
Autorun--folder
authorized_keys=-- file you need to create and add
and other files that were in tared
after done left the same error. and router queries login...
Hey guys, maybe someone here can help me.
I'm currently running this version of the firmware and i keep getting random restarts on a nearly daily basis and have no clue why this is happening. Log File only states that firmware is initialized after the reboot so i can't check what happened before the reboot.
Any of you guys has any idea what i can do to fix those random restarts ?
unfortunately i did a factory reset twice. It actually looked like the problem was gone after the second try. But that was just because the restarts happened when nobody was home. I'm checking the logs every day since about a week now and there is a restart happening nearly every day at some point. I also checked if the router gets hot or something but its just a little warm to the touch and it's placed out in the open with no direct sunlight.Have you done a "reset to factory defaults" since you flashed the firmware? That's the first thing that I'd try, is a reset to factory defaults, then manually re-enter your configuration settings. That will most likely take a few minutes, but if you haven't done it might fix this sort of problem.
Welcome To SNBForums
