Custom firmware build for R7800 v. 1.0.2.31SF
Smartphone config downloaded from router's GUI is using TUN. So no way. Or seek for TAP OpenVPN client and modify your client config for TAP. I know one guy is using TAP for his Android with my build.
Voxel.
Voxel is right. I use tun on my phone, but my windows pc uses tap. It should work just fine. Import config and go.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Even for the 32F for me the QOS broke. I had to go back to stock for the Netgear support needs remote. When flashed your 32F . It comes with v4.0 . But initially it was fine and then it broke the same day.
Now i am downgraded and letting it settle down.
ulaganath,
I came across this post on NG forums and it sounds like the same issue you've been having with QoS.
https://community.netgear.com/t5/Ni...no-upload-download-metrics/m-p/1298124#M58876
Sent from my SAMSUNG-SM-G935A using Tapatalk
Voxel have ever considered adding irqbalance, for CPU load balancing? I assume it's not there in stock as I couldn't find any reference to it.
