Custom firmware build for R7800 v. 1.0.2.44SF
So your back using NG Stock FW and trying to load the saved back up from from Voxels v44SF? if so, that won't work. Youll have to migrate back to Voxels v44SF FW to load the saved back up file from that saved version. The v44SF back up file only works on Voxels version of FW, not NG stock FW.
If you want to clear items you configured, via UI or otherwise, a factory reset is only needed. No need to load FW again, OEM or Voxels.
NO, i am pretty experienced at this.
On Voxel firmware I had a Voxel saved config file
On Stock I had a stock saved config file
On Voxel, when you goto the screen to load the config file, the explorer box opens, I select the saved Voxel config file, but the file never appears in the box and thus cannot load it.
Have you tried to save a config and load? Please try and tell me if it works.
CC
Ok, so I'm on v44SF. I did another back up to file. I factory reset the router. Walked the wizard. Navigated to Backup settings and selected Browse, selected the back up file. Then selected Restore. Router seems to take the file since the IP address changed from .1.1 to a different ip addresses string I use. Was able to log in again to routers Ui at new IP address i use.
CC
Yes, it is working. BUT: After you select the *.cfg file and press Open, you are returned to the "Backup Settings" form.
At this moment the file name is invisible...
But if you put the cursor above the empty "Restore settings from a saved file"-box, the file name is shown!.
Also if you press the Restore button, the backup-file will be used and your settings are restored.
So, yes there is a bug here, but it is still working.
this is not version related .. but folders and files made by torrent (stock or transmission) are created with 755 permission .. only owner can edit/write/delete .. so I am not able to rename or delete files/folders .. cannot change permissions .. share setting do not ask for admin (admin is not checked in webgui) any hints? other files that I copy to HDD attached to R7800 are free to edit/delete .. as guest ..
Kamoj.
You are probably correct, when I did not see the file in the box (as stock) I thought there was a bug and did not
complete the restore.
CC
Probably a minor UI bug. File name should be displayed upon selecting the back up file.
The restore process works and works correctly though.
Well, maybe. I'll check. In general I've used web pages and CGI processor from stock fw w/o changes. But codes of latest stock are not published still. Maybe they corrected this bug.
Voxel.
You can map your HDD to your computer as "root" user. With full root permissions. Password is the same as in WebGUI for admin.
Voxel.
Voxel.
Voxel,
Reflashed R7800-V1.0.2.44SF, factory reset, then restored my settings (like reported the files shows up if you put the pointer over the box) Now my router is running perfectly! Bufferbloat has improved 95% and now getting A wired and B wireless!
I am not changing a thing now. Thank You!
CC
Thing about the saved settings file name not showing when restoring is kind of spookie. Fools you into thinking that the functionality is broken until you just try it.
Odd behavior.
Hello Everybody! Happy New Year! Just tested this firmware. L2TP still isn't working. Waiting for the actions from Netgear...
You might post in the NG forum as well if the OEM Version of FW isn't working either.
NG needs to know if there FW isn't working correctly for that particular feature.
I've sent note to Netgear Guy 1 firmware ago. He assured me that NG will take care of it. Hoping and waiting...
Good luck.
