Custom firmware build for R7800 v. 1.0.2.72SF
Again, thanx a LOT for your work Mr Voxel. And for the time you spend replying to many posts here (and there?) you're always available and your posts are really detailed and more :)
I am having a problem where I lose DNS after a few hours. I suspect DNSCrypt is crashing. A reboot of the router fixes it, but I'm sure there's an easier way. I'll try to post a log when it happens again.
I've got a doubt about the firmware update steps.
This is my workflow:
1. Update the firmware.
2. Reset to factory defaults.
3. Restore previous config with a backup file I did before the first step.
I understand that restoring to defaults, it cleans everything, and then, with my backup file, it restores just the proper data, without any kind of junk.
Am I wrong?
Cheers
This my workflow:
Am I wrong?
Cheers
Hello,
I never reseted to factory default before updating to a new Voxel firmware and my router is working great :)
Continuation of
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-69sf.58293/
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-70sf.59009/
New version of my custom firmware build: 1.0.2.72SF.
Changes (vs 1.0.2.70SF):
1. minidlna package is upgraded 1.2.1->1.2.1-2018-04-10.
2. (minidlna) ffmpeg package configuration is changed (to provide more stable support of the FLAC files).
3. (minidlna) ffmpeg compilation flag conflict is fixed (now it is pure Cortex-A15 target).
4. (minidlna) libogg package is upgraded 1.3.3->1.3.4.
5. (minidlna) sqlite package is upgraded 3290000->3300100.
6. expat package is upgraded 2.2.7->2.2.9 (CVE-2019-15903).
7. unbound package (used in stubby) is upgraded 1.9.3->1.9.4 (CVE-2019-16866).
8. DNSCrypt Proxy v.2 is upgraded 2.0.27->2.0.28.
9. dnsmasq package is upgraded 2.78->2.80.
10. curl package is upgraded 7.65.3->7.66.0.
11. haveged package is upgraded 1.9.6->1.9.8.
12. libubox package is upgraded 2019-06-16->2019-10-21.
13. transmission-web-control package is upgraded 2019-04-16->2019-07-24.
14. dropbear package is changed: to allow ssh forwarding.
15. e2fsprogs package: optimization for a size.
16. patch package is added (kamoj add-on, replacement of a busybox analog).
17. coreutils sort package is added (kamoj add-on, replacement of a busybox analog).
18. etherwake package is added (kamoj add-on).
19. busybox: sort and patch are disabled.
20. OpenSSL 1.0.2/1.1.1: make an order with patches.
21. Host tools (mtd-utils): Add: glibc >= 2.28 compatibility patch.
22. Host tools (m4): Add: glibc >= 2.28 compatibility patch.
23. Host tools (squashfs4): Add: glibc >= 2.28 compatibility patch.
24. Toolchain: gdb is upgraded.
25. Development platform is changed (Debian9->Debian10: glib 2.24->2.28; gcc 6.3.0->8.3.0; etc).
26. Support of new certificates for https.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Voxel.
Installed a few minutes ago.
Thank you Voxel!
LIKE!!!
Everything was working fine since this morning but I just lost DNS again. I was able to get it back by restarting dnscrypt-proxy-2:
/etc/init.d/dnscrypt-proxy-2 restart
The log /var/log/dnscrypt-proxy-2.log doesn't show anything happening. Is there another log I can look at?
Can somebody post dslreports.com/speedtest results with hi-res bufferbloat enabled in speedtest settings from 5G WLAN while on .72SF firmware?
Do you use your own config /etc/dnscrypt-proxy-2.toml?
dnscrypt-proxy-2 executable binary is used "as-is" in my firmware. It is prepared by author of dnscrypt-proxy-2.
But make sure if you are using your own config that it could be changed from version to version. So if you need your own servers just edit /etc/dnscrypt-proxy-2.toml from latest firmware. Original file (firmware version) is available: /rom/etc/dnscrypt-proxy-2.toml
FYI I do use it for 3 routers. Uptime is more than 3 days and it is working still... My log
[2019-10-24 15:40:07] [NOTICE] dnscrypt-proxy 2.0.28
[2019-10-24 15:40:07] [NOTICE] Network connectivity detected
[2019-10-24 15:40:09] [NOTICE] Source [public-resolvers.md] loaded
[2019-10-24 15:40:09] [NOTICE] Firefox workaround initialized
[2019-10-24 15:40:09] [NOTICE] Now listening to 127.0.0.1:64153 [UDP]
[2019-10-24 15:40:09] [NOTICE] Now listening to 127.0.0.1:64153 [TCP]
[2019-10-24 15:40:09] [NOTICE] Now listening to [::1]:64153 [UDP]
[2019-10-24 15:40:09] [NOTICE] Now listening to [::1]:64153 [TCP]
[2019-10-24 15:40:09] [NOTICE] [scaleway-fr] TIMEOUT
[2019-10-24 15:40:10] [NOTICE] [cloudflare] OK (DoH) - rtt: 4ms
[2019-10-28 07:41:51] [NOTICE] -     8ms cloudflare
[2019-10-28 07:41:51] [NOTICE] -    39ms dnscrypt.eu-dk
[2019-10-28 07:41:51] [NOTICE] -    46ms soltysiak
[2019-10-28 07:41:51] [NOTICE] -    55ms dnscrypt.eu-nl
[2019-10-28 07:41:51] [NOTICE] -    61ms scaleway-fr
[2019-10-28 07:41:51] [NOTICE] Server with the lowest initial latency: cloudflare (rtt: 8ms)
Voxel.
Absolutely. I never overwrite the file. The default file gets edited.
