Voxel Custom firmware build for R7800 v. 1.0.2.91SF & v. 1.0.2.91.1SF
I am trying to set up DNS-exits' dynamic DNS to update every 3 min by using curl, I've verified that the curl command does what its supposed to do in an SSH sesh but I am not sure how to continue from here. I was thinking add a cronjob but /etc/crontabs/root does not seem to be persistant and always reverts back to the original file (during boot-time I guess, or perhaps crontabs get generated every boot idk but changes wont stick after a reboot). Anyone has a solution?
this is the command I am trying to cron
Bash:
/usr/bin/curl https://api.dnsexit.com/dns/ud/?apikey=API-KEY -d host=host1.yourdomain.com
This stuff (enabling respond to ping) is inside of the pre-built binary 'net-cgi' from the GPL by NG/DNI. So sorry, I cannot change its behavior. But do you really change OpenVPN ON/OFF too often? I just do enable it with disabling 'respond to ping' and forget it almost forever...
Voxel.
Voxel, thanks for the info. I don’t leave the OpenVPN server running all the time but now that I know this is the expected behavior, I will just remember to deal with it manually.
Bash:
Try to use @kamoj add-on.
Voxel.
Bash:
The default cron is no good for customized rules.
two three ways:
1) as @Voxel suggested, use the @kamoj addon that uses its own cron for custom tasks. And makes it easy.
2) use Entware and install cron through it, and you will have a functional cron.
3) use a custom script and launch your own cron daemon, but only if you know what you are doing…
Does anyone using latest Voxel firmware with VLAN enabled on R7800?
I was trying to enable VLAN on my R7800 with 91.1SF + Kamoj 5.5b18 and end up with disconnected Internet.
Setup wizard / problem detection / ISP DHCP release / renew is not working and I found the following error in the logs:
device brwan entered promiscuous mode
device brwan left promiscuous mode
NET: Unregistered protocol family 24
brwan: port 1(ethwan) entered disabled state
device eth0 left promiscuous mode
device eth0 entered promiscuous mode
DNI-QOS: Qos is disable
DNI-QOS: Qos is enable
brwan: port 1(ethwan) entered forwarding state
brwan: no IPv6 routers present
ethwan: no IPv6 routers present
msm_nand_read_oob 57f0800 800 0 failed -74, corrected 0
UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 283:67584, read 64 bytes
msm_nand_read_oob 57f1000 800 0 failed -74, corrected 0
UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 283:69632, read 64 bytes
msm_nand_read_oob 57f1800 800 0 failed -74, corrected 0
UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 283:71680, read 64 bytes
msm_nand_read_oob 57f2000 800 0 failed -74, corrected 0
UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 283:122880, read 64 bytes
msm_nand_read_oob 57fe800 800 0 failed -74, corrected 0
UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 283:124928, read 64 bytes
msm_nand_read_oob 57ff000 800 0 failed -74, corrected 0
UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 283:126976, read 64 bytes
msm_nand_read_oob 57ff800 800 0 failed -74, corrected 0
UBI error: ubi_io_read: error -74 (ECC error) while reading 64 bytes from PEB 283:129024, read 64 bytes
everything back to normal when I disable VLAN... and no such errors in the log occuring anymore...
I have also tested on fresh factory reset Voxel firmware and the same errors occuring so not related to Kamoj add-on nor Aegis etc...
Not tested with vendor original firmware as as it's not sable in 90+ versions as per my expirance...
OK, I have tested VLAN with different firmwares (Netgear .90 , .86, .68) different ISP (LTE including) and "Internet" was not available with VLAN enabed... so I have started reading R7800 user manual as you are always comming back to manuals when something is not working ;) - not before setup :P
It looks like VLAN on our routers are only for solutions like IPTV where LAN device needs direct acccess to ISP services - this is not a real VLAN setup for LAN without WAN affecting... Anyone know if we can setup real VLANs on R7800/R900 series routers or ProSafe (business) series are required?
For the UBI / mtd errors I have reset settings many times during different firmwares testing and as found in older posts - I have disabled Traffic Meter and all ECC errors for "netgear" were gone after reboot...
OK, I have tested VLAN with different firmwares (Netgear .90 , .86, .68) different ISP (LTE including) and "Internet" was not available with VLAN enabed... so I have started reading R7800 user manual as you are always comming back to manuals when something is not working ;) - not before setup :p
VLAN on stock/Voxel firmware is meant for specific services, as you mentioned. It's not a full blown VLAN option, so no
I thought that maybe with some additional "entware" packages it will be possible... ;)
I have found a strange information in the "dmesg" log:
wlan_bsteering_measure_chan_util: Already waiting for utilization, VAP is not ready, or bsschan is invalid on interface aa:bb::cc:dd:ee: cda01100
(mac address changed - it was MAC of my 2,4Ghz wifi )
After investigation I have found on other forums that this was related to wifi scheduling (that was not enabled on my router) so I have enabled it and than disabled it and the errors were gone... for 24h only
Today I have logged into my router to make sure no errors and found 4 occurrences of the same error...
I cannot find anything for such error on our forum so question if anyone had experienced such errors?
When this error occuring I get my mobile devices disconnected from 2,4Ghz network and no such errors (and no disconnects) for 5Ghz network.
