matthew johnson
What's the difference between the hw versions of your firmware and the other?Yes almost the same.
Voxel.
Sent from my SM-G965U1 using Tapatalk
Voxel.
HW means hardware acceleration of OpenSSL. It means that some functions e.g. OpenVPN should work faster. I use HW version with my R9000.What's the difference between the hw versions of your firmware and the other?
Thank you. I just purchased a R9000 yesterday.HW means hardware acceleration of OpenSSL. It means that some functions e.g. OpenVPN should work faster. I use HW version with my R9000.
Voxel.
Voxel,
Thank you my friend.
Can you answer this question too?
"I have read that your firmware is based on Genie and IS NOT DD-WRT, so does that mean all I have to do is grab the latest firmware and flash the router? Or do you have to use an "Initial" build as you do with DD-WRT?"
Appreciate it!
Tom
Yes, as I said nothing special, flash downloaded latest firmware. There is no any initial.
Voxel.
I do provide some help (as much as I am able). I do not think that payed support would be interested for usersPS, as an idea, you might want to start an officially supported version of your firmware where people simply pay a one time fee or something. I'd be interested.
Yes, just unzip downloaded archive and use WebGUI to flash resulting IMG-file. No other tools/programs are needed.Do I just go to the current NG admin login and upload the file from your site and it should be fine .. ?
Welcome To SNBForums
