New Version: *3.0.0.4_378.50_HGG-V1*
http://forums.smallnetbuilder.com/showpost.php?p=155407&postcount=1
Will DFS work with your Firmware and with the combination of RT-AC68U and PCE-AC68?
I live in Europe and DFS is important here
DFS and TPC are either implemented in the code or they aren't. Whether you use a PCE-AC68, or any other wireless adapter has nothing to do with DFS or TPC (it's a slave device....wireless cards and adapters aren't required to include DFS or TPC in them, only devices that work as routers.
Hggomes has made some interesting statements in this thread, including that DFS and TPC work "with the right settings", or that his "region" has different requirements than the rest of the EU. Um....not so.
Still no git, no source code available. As Got_Milk says, this is an enormous huge red flag.
I have this router also didn't get 16u because it's an older router and the same price with 18u which has higher specs , how does the interface of this build looks like ? has anyone tried this on a rt-n18u?
I have flashed the latest FW (3.0.0.4_378.50_HGG-V2) complete re-flash, factory, nvram erase...and have 2 issues.
1st: I'm not able to change wan MAC address through webui
When I come to WAN/internet connection tab, I only see USB modem settings.
I have spend good amount of time looking for it, so I don't think I missed it
2nd: It is not possible to mount jffs. I can see in nvram settings that it is enabled, it gets formatted, but never gets mounted. Tried several reboots (enable, reboot, format, reboot, reboot, reboot, disable, reboot ... you get the idea)
Any ideas?
Unfortunatelly i cannot test it because i dont have the router at this moment with me, but have you noticed that only on V2? You have told me all was working fine on a previous FW version...
Tks for your feedback.
Not sure what you understood from that, my region is EU, so DFS and TPC will work fine. What i ment was that DFS and TPC will not work if you are on a lower channel than 100 for example.
Not sure what you understood from that, my region is EU. . . .
question.
why do asus cap at 80mw when the EU limit is 200mw and even higher for higher channels?
Not all regions of EU, in my country the maximum allowed is 100mW, it depends on the specific region.
Hello,
When i activate parenstcontrol after the update the cpu goes 100%. When i only activate nothing happens but when i fillin a device and save then it goes 100% and stays there. Kow issue fot the asus rt-n66u?
grt
Pierre
Indeed, that problem happens on alpha versions, i will add lastest stable 376 version, that problem doesnt happen on it.
That specific problem you reported does this:
RT-N18U, RT-AC56U, RT-AC68U, RT-AC87U = CPU stays at 50%
RT-N16, RT-N66U, RT-AC66U = CPU stays at 99%
PORTUGAL, 100mW is the limit here, page 191.
http://www.anacom.pt/
http://www.anacom.pt/streaming/qnaf20092010_07042010.pdf?contentId=1019281&field=ATTACHED_FILE
Quiz:
EU DFS/TPC: 5470 - 5725 MHz (100-140)
4.7.1.2 Applicable frequency range
Radar detection is required when operating on channels whose nominal bandwidth falls partly or completely within the frequency ranges 5 250 MHz to 5 350 MHz or 5 470 MHz to 5 725 MHz. This requirement applies to all types of RLAN devices regardless of the type of communication between these devices
Welcome To SNBForums
