What graph?my bad i saw 1.0 here in the graph so i thought you didn't use the updated firmware
Sorry, my error. Fixed.http://www.smallnetbuilder.com/content/view/30588/96/1/2/
Under routing performance
Not likely. The product is grossly overpriced.Any chance you (Tim) might re-review it to see if the problems have been fixed?
The supposedly fixed (A2) version of the 855 is now becoming available from online merchants. Any chance you (Tim) might re-review it to see if the problems have been fixed? The 825 seems a bit underwhelming, leaving the revised 855 my only hope of a near term dual-band replacement for my 655.
I'm trying to get to the bottom of this one small problem I have with my DIR-825, and am wondering if anyone has seen it? I have emailed D-Link Tech Support, gone to their forums, and have generally been ignored....
Sorry, lost track of what connects to what. And what is a WPA300N?
The DIR-825 is the only gigabit device of the ones you mention. Perhaps your problem is related to it.
Do you have another gigabit switch that you can try?
I would grab a copy of WireShark and run a trace plugged into an 825 port.
Also thought of two other possibilities: make sure the DHCP server is off and also shut off UPnP and WISH.
Welcome To SNBForums
