D7800 New Firmware 1.0.1.10
xander73
Release Notes:
Enhancements
Supports ReadyCloud, which allows you to access your USB storage device from anywhere.
Supports genie remote, which allows you to manage your home network remotely using NETGEAR genie.
Supports the Kwilt iOS photo manager app, which can be used to view and share photos stored on the USB drive connected to the R7800, as well as from other sources like DropBox, OneDrive, Facebook etc.
Supports NETGEAR Downloader (Beta), which allows you to directly download files from Internet to the USB drive connected to the router.
Supports OpenVPN mobile client (iOS and Android) app for easy secure remote access to your home network.
Sends log reports via SSL email, which allows email notification to be setup on your Nighthawk router.
Supports WiFi Transmit Power Control, which reduces WiFi power to just cover your home network and reduces WiFi interference in the neighborhood.
Supports AP mode detection, which detects whether you set up the router in AP mode or not, and provides you with the option to configure the router in router mode or AP mode.
Supports IPTV port, which creates a bridge connection from the WAN port to one of the LAN ports. The designated LAN port or wireless SSID becomes an IPTV port, and has the direct access to the WAN port, without going through NAT.
Supports IGMP proxy for British Telecom.
Improves port forwarding by allowing fixed and range ports to be added to one rule.
Supports IP-MAC binding for the PR region.
Supports Super WiFi for the PR region.
Supports DNS 3322 for the PR region.
Supports Russian WAN installation and IPTV port support.
DFS channels for european costumer are gone with this update. What is the reason for this choice?
Have you hard reset the router and configured it manually after the update? Also I thought you had a R7800, sorry if you have changed that, its just your last few posts were about the R7800 not D7800.
The D7800 CE DFS support is planned to be added in the next FW release by the end of Sept..
Until the previous release channels were available. They were removed to be remitted?
I have a pre-purchase question.. :) My ISP announced a migration in the next year to the 35b VDSL profile (or 200mbit VDSL speed).
Can the D7800 chipset handle this VDSL profile protocol?
