DDNS - duckdns.org
Anyone for duckdns,org to work. I am running asus-rt n66u with 378.51.
I created ddns-start and have custom jffs scripts enabled. Ddns-start is updated by the logs just fine, but when I test it out not working. I have static the dns to opendns and went to opendns.com/welcome to test whether; it was using opendns or not. It was still using the opendns. Any help be appreciated. I tried the wan-start but that didnt work either.
This is my script:
<code>
#!/bin/sh
touch /tmp/000wanstarted
sleep 45
curl -k -s "https://www.duckdns.org/update?domains=domainname&token=XXXXXXX&ip="
if [ $? -eq 0 ]; then
/sbin/ddns_custom_updated 1
else
/sbin/ddns_custom_updated 0
fi
</code>
Your URL has an "ip" argument at the end but you don't provide any IP. Maybe that's causing the problem. Try appending the IP, contained in $1 (if using within a ddns-custom script).
I will try and add my IP at the end of the URL and see if that works when I get home from work. Thanks Merlin.
I have just signed up and I have just bought an asus rt-ac87u.
I am interested as well in using ddns service of duckdns.
Looking at this wiki guide, at this guide on fritzbox and at the posts above, I hope that the following simple script will work:
#!/bin/sh
# Use duckdns.org service on your router
# First step: register on duckdns.org site and choose a subdomain name and note the generated token
# Second step: fill in the double quotes below the information needed
DOMAIN=""
TOKEN=""
/usr/sbin/curl --silent "https://www.duckdns.org/update?domains=$DOMAIN&token=$TOKEN&ip" > /dev/null 2>&1
if [ $? -eq 0 ];
then
else
fi
exit 0
I have not tested this script yet as I have not configured the router neither, therefore your feedback would be really appreciated.
giopas
Thanks hawke84, the script I have wrote above is quite similar to yours and should therefore work (still to be confirmed though, as I still need to configure the router).
this worked for me
#!/bin/sh
curl -k "https://www.duckdns.org/update?domains=xxxxx&token=xxxxxx
else
fi
fill in the xxx with your domain and token.
save this as ddns-start
my original thread:
http://www.snbforums.com/threads/duckdns-setup.24784/
I have a slight variant of that working where it captures and tests the response from DuckDNS. Otherwise I found that the script always signaled a success, even if the update hadn't occurred:
#!/bin/sh
result=$(curl -k --url "https://www.duckdns.org/update?domains=<DOMAIN>&token=<TOKEN>&ip=")
if [[ $result == "OK" ]]; then
else
fi
@RMerlin how would i go about incorporating duckdns into your script https://github.com/RMerl/asuswrt-merlin.ng/wiki/Custom-DDNS
Using a DDNS with VPN
below is the current working script
#!/bin/sh
# register a subdomain at https://www.duckdns.org/ to get your token
SUBDOMAIN="xxxxxxxxxxx.duckdns.org"  *xxxxxx = removed for security*
TOKEN="xxxxxxxxxxxxxxxxxx"   *xxxxxx = removed for security*
# no modification below needed
curl --silent "https://www.duckdns.org/update?domains=$SUBDOMAIN&token=$TOKEN&ip=$1" >/dev/null 2>&1
if [ $? -eq 0 ];
then
else
fi
Please can you help as you're the master at these things?
here is the current script and that's working
#!/bin/sh
if [ $? -eq 0 ];
then
else
fi
I haven't tried this myself, but I think should just be able to copy your script into /jffs/scripts and rename it to ddns_start.
Make sure you set the DDNS page to "Custom" and ensure you enable JFFS scripts on Admin/System page:
Let us know how that works.
Thanks for trying to help me :)
Funnily enough that's how i did it, created script on router, made sure properties were correct and turned on custom_ddns and added hostname etc it registers sucessfully .....what i would like to know is how i link ddns to a vpn
@RMerlin can you provide some magic scripting please if it is doable?
Did you try the VPN example? You might need to change the tun11 lines if you're using a different client instance.
#!/bin/sh
if [ "$script_type" = "up" ] && [ "$vpn_interface" = "tun11" ]; then
    # OpenVPN tunnel won't open until openvpn-event script is finished, run the rest in a background shell
        # Loop until VPN tunnel is established or the timeout limit is reached
        COUNTER=0
        LIMIT=10
        while [ "$COUNTER" -le "$LIMIT" ] && ! ifconfig | grep -Fq "tun11"; do
            sleep 1
            COUNTER=$((COUNTER + 1))
        done
        curl -fs -o /dev/null "https://www.duckdns.org/update?domains=$SUBDOMAIN&token=$TOKEN"
fi
#!/bin/sh
        COUNTER=0
        LIMIT=10
            sleep 1
        done
fi
Thanks, bomber looks like just what i was needing :) quick question would workout what tunnel is in use, like a list?
The ifconfig command should show which tunnel you're using.
still working my way through setup of different things...atm xmrouting
