DDNS
Forcing update can be done in 2 ways.
1. In router gui under WAN->DDNS click Apply
2. SSH to the router and execute sh /jffs/scripts/ddns-start
As i can see, ddns-started is only Called at the end of a DDNS update process.
Maybe I want to use wan-event, Called after an event related to the WAN interface occurs.??
What to put on chmod?
And how to edit the script?
I'm really newbie at this
Once you ssh to the router run command chmod +x /jffs/scripts/ddns-start. This will make the script executable. As for editing the file you can use vi or nano editors. Find out on web how to use it. nano is easy to use.
1. cd /jffs/scripts
2. nano ddns-start
3. Edit the file. You can copy paste and edit
4. Save the file using ctrl-o and then ctrl-x
Done.
It didn't worked as expected:
Mar 13 01:28:12 rc_service: httpd 1000:notify_rc restart_ddns #when i set to custom DNS
Mar 13 01:28:12 custom_script: Running /jffs/scripts/service-event (args: restart ddns)
Mar 13 01:28:12 start_ddns: update CUSTOM , wan_unit 0
Mar 13 01:28:12 custom_script: Running /jffs/scripts/ddns-start (args: 192.168.1.2)
Mar 13 01:28:14 ddns: Completed custom ddns update #correctly updated
Mar 13 01:28:48 DualWAN: skip single wan wan_led_control - WANRED off # i forced an IP update from ISP
Mar 13 01:29:07 WAN_Connection: WAN was restored. #new IP assigned
Mar 13 01:29:07 rc_service: wanduck 927:notify_rc stop_ntpd
Mar 13 01:29:07 custom_script: Running /jffs/scripts/service-event (args: stop ntpd)
Mar 13 01:29:07 rc_service: wanduck 927:notify_rc start_ntpd
Mar 13 01:29:07 rc_service: waitting "stop_ntpd" via wanduck ...
Mar 13 01:29:08 custom_script: Running /jffs/scripts/service-event (args: start ntpd)
Mar 13 01:29:08 ntpd: Started ntpd
As you can see, as the WAN as restored (new IP assigned), it didn't update my external IP address
The problem I see is your script ddns-start is passing your local IP to DDNS server.
You have to modify the script and provide DDNS provider your WAN IP. Look at the script I gave you. You will see a line
IP="$(curl -fs4 https://myip.dnsomatic.com/)"
This retrieves WAN IP and then I call DDNS provider API and pass the WAN IP
curl --silent "https://www.duckdns.org/update?domains=$SUBDOMAIN&token=$TOKEN&ip=$IP" >/dev/null 2>&1
Any other code you may have put in service-event for DDNS you need to remove it.
You have to do similar thing as well. When the code is working properly you can verify that
1. It completes without error
2. Access DDNS provider web page and you should see your WAN IP there.
But now you need a reliable way to detect the public IP change from behind your double-NAT, so you can trigger ddns automatically.
That’s already build in to Merlin firmware if using custom method and ddns-start script. This is in wiki documents written by Merlin.
As I mentioned when firmware detects WAN IP change it calls ddns-start script.
I guess it’s late for me and my thinking is slowing down, but how will DDNS get triggered if the router’s own WAN IP (which is not the public IP) does not change?
Maybe its built in, but it doesn't work.
Because when WAN ip changes it doesn't detect.
Simpliest way - I set up a cron job every 5 minutes to update the IP on dsomatic :)
So, I created a cron job each 10 minutes to run this script, and it works very well.
USERNAME=NAME
PASSWORD=PASS
HOSTNAME=all.dnsomatic.com
CURRENTIP="$(curl -fs4 https://myip.dnsomatic.com/)"
/usr/sbin/curl -k --silent -u "$USERNAME:$PASSWORD" "https://updates.dnsomatic.com/nic/update?hostname=$HOSTNAME&wildcard=NOCHG&mx=NOCHG&backmx=NOCHG&&myip=$CURRENTIP" > /dev/null
if [ $? -eq 0 ]; then
  /sbin/ddns_custom_updated 1
else
  /sbin/ddns_custom_updated 0
fi
Howver, sometimes I get response "abuse" and the IP doesn't update, as i'm abusing the server. So, I came up with an ideia, but as I dont know which programming language is that and I dont know it very well, I need something like that (i'll put in red what I want to do). If everyone can write that script for me, that'd be wonderfull!!!
USERNAME=NAME
PASSWORD=PASS
IPONDOMAIN = get the IP that the domain is currently pointing at
if CURRENTIP different than IPONDOMAIN then
/usr/sbin/curl -k --silent -u "$USERNAME:$PASSWORD" "https://updates.dnsomatic.com/nic/u...=NOCHG&mx=NOCHG&backmx=NOCHG&&myip=$CURRENTIP" > /dev/null
else
fi
ELSE
print_message_on_log "Nothing to update"
end if
Thanks!
IPONDOMAIN="$(nslookup my.example.com | grep -oE '([0-9]{1,3}\.){3}[0-9]{1,3}' | awk 'NR>2')"
if [ "$CURRENTIP" != "$IPONDOMAIN” ]; then
Perfect dave, thank you so much!
And how to write the "else", "end if" and how to write a message to router log (so I can read them on log page)?
I wouldn’t want a log message every 5 minutes in the syslog just to say nothing happened.
else
  logger -t myddnsscript.sh "Nothing to update"
fi
Yes, it's just to test right now to see if it runs ok! :)
thank you sir.!!!
Right now I have a 5 minutes message saying it's updated... So the idea is stop it :)
Which programming language is this? So I can study a bit...
It is not a good behave to update every 5-10 minutes. You will be banned very soon. Cache your ddns update and ONLY update when it's changed. {ok post 31}
Yes, i just managed, with Help from Dave, to do that.
First i do a nslookup for my domain. If my current ip is the same as nslookup, doesn't do nothing. If it's different, than updates.
What address do you lookup? okey your ddns name..........
