I would be grateful if someone could take a minute to tell me if I have returned the settings in Professional to "default" (I have entered a number of static leases and some port-forwarding and would prefer to not do a reset to default) (I could not find them in the manual)
Are these the correct defaults (for both 2.4GHz and 5GHz)?:
Roaming assistant: disable
Enable IGMP snooping: disable
Multicast Rate: auto
Preamble type: short
AMPDU RTS: enable
RTS Threshold 2347
Enable TX bursting: enable
Enable WMM APSD: enable
Optimize AMPDU aggregation: disable
Optimize ack suppression: disable
Airtime Fairness: disable
802.11ac Beamforming: disable
Universal Beamforming: disable
Thanks.
AMPDU RTS: enable
RTS Threshold 2347
Thanks.
