Defunct cfg_server Zombies
I noticed that every time the zombie slayer script ran, I wound up with 0 cfg_server processes running, instead of 3 or so.
So, I thought “could it be that it’s killing the wrong process first‽” and fixed up your edits to make sure not to kill that one. But still I was winding up with zero. I decided to add a break to only kill one process. Again zero. Grabbed a random one from the list and ran kill -15 pid. all dead.
I have once again run up against the edges of my cleverness. Here’s the state of the script, which I’m quite happy with overall and would use if I didn’t have that second node. (note: this happens whether or not one has multiple nodes, to say nothing of AIMesh)
TL;DR runaway cfg_server issues will happen regardless of AIMesh usage; killing one of the 1012 processes kills them all, killing connection to nodes; i have no idea how to deal with root cause
(re root cause: As @SomeWhereOverTheRainBow points out: lockfile? process never returning? idk)
#!/bin/sh
# This script relies on parsing strings, don't include `cfg_server` in its name
awk_pidof() { ps wT | awk '/\scfg_server/{if( $0 !~ /awk/)printf "%s ", $1}'; }
if [ "$(ps wT | awk -v var="$(basename "$0")" '{if( $0 !~ /awk/ && $0 ~ /$var/ )printf "%s ", $1}' | wc -w)" -gt 1 ]; then
  echo "Exiting zombie slayer because it thinks it's a duplicate process"
  exit;
fi
while :; do
   while [ "$(awk_pidof | wc -w)" -le 3 ]; do sleep 5; done;
   /usr/bin/logger "Zombie slayer detects excess cfg_server processes"
   # echo "Zombie slayer detects excess cfg_server processes"
   i=0
   parent_pid=$(pstree -s cfg_server | awk '{if($0 !~ /init/)printf "%i", $2}')
   for pid in $(awk_pidof); do
      if [ "$pid" != "$parent_pid" ]; then
         # echo "killing pid $pid"
         /bin/kill -s 9 $pid &
         # /usr/bin/logger "Zombie slayer killing pid $pid"
         i=$((i + 1))
         break
      fi
   done
   /usr/bin/logger "Zombie slayer back to sleep after killing $i processes"
   # echo "Zombie slayer back to sleep after killing $i processes"
done
inevitably someone is going to say “why don’t you just kill all the processes always and forever, and switch how your nodes work?" the short answer is, i’m a software person not a hardware person and i dread having to think about channels and juggling multiple SSIDs and whatnot. I only need the second node for a tiny corner of my home, but I *need* that node for that tiny corner of my home.
What happens if you send
kill -s 17 to the parent process only? I wonder if that kills both the parent process and child processes.
of course! child signal!
but ugh, it did nothing. router continued to have approx 1012 cfg_server processes running. I even tried running a loop and sending it to every process in case there was a cascade I could kick off somewhere. No dice.
So, what is your network topology. I mean what are you using as node(s), and what firmware version are you using on your node(s) and your main router?
2 x ZenWiFi_XT8 (base model: RT-AX95Q); Firmware Version 388.1_0-gnuton1 with an ethernet backhaul. Main is set up as "Wireless router mode / AiMesh Router mode”, second set up as an AiMesh node.
I am playing with the script right now.
Testing it with my own self made defunct lol.
#!/bin/sh
  exit;
fi
while :; do
   i=0
   parent_pid=$(pstree -s cfg_server | awk '{if($0 !~ /init/)printf "%s", $2}')
      if [ "$pid" != "$parent_pid" ] && [ "$i" -gt "2"]; then
         /bin/kill -s 9 $pid & slay_pid="${slay_pid} $!"
         i=$((i + 1))
      fi
   done
   wait $slay_pid
   unset slay_pid
done
I removed the break so the loop will continue, I added [ "$i" -gt "2"] to make sure we keep at least 3 PID.
