Disabling FC and running speedtest
archiel
lol no difference here
fc disabled
fc enabled
i only have wifi devices which are capable of 1Gbps
i use a crappy laptop with a usb c to ethernet (no direct ethernet connection possible )
fc disabled View attachment 55360
fc enabled View attachment 55361
Thank you very much for testing - the drop is as feared (and as advised) and helps me with eliminating options (to get my internet connection working at full speed while still retaining WireGuard)
Hi, I am not sure what you are suggesting I look at here. In order to run WireGuard (WGM) the settings that seem to work best are Runner: enabled Flow Cache: disabled. However with Flow Cache disabled, all internet traffic is speed limited (450/500 down from ISP 1Gb symmetric) not just that flowing through the VPN(s).
