disk space on rt-68u..
TrevP
Do I need to worry about this?
ASUSWRT-Merlin RT-AC68U 380.65-2 Fri Mar 10 05:29:50 UTC 2017
admin@RT-AC68U:/tmp/home/root# df -k
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 31616 31616 0 100% /
devtmpfs 127744 0 127744 0% /dev
tmpfs 127848 1172 126676 1% /tmp
/dev/mtdblock4 64256 6632 57624 10% /jffs
Specifically the root filesystem? IT's been like this for months. I'd hate to have an OS upgrade fail because of this. I can't see where exactly I can free up disk on that filesystem. Most disk used is under /lib, /usr and /www. Don't want to piss around with /lib and /usr, if at all? What is under /www that can be cleaned up?
admin@RT-AC68U:/# du -sk * (removed other filesystems for brevity; /dev, /tmp, /jffs)
0 asus_jffs
1688 bin
0 cifs1
0 cifs2
0 etc
0 home
11406 lib
0 media
0 mmc
0 mnt
0 opt
0 proc
5613 rom
0 root
1077 sbin
0 sys
0 sysroot
50721 usr
0 var
16475 www
