Asus RT-AC86U and Debian Bullseye + Nextcloud
All of the above to run nextcloud in a easy way.
I have no experience using nextcloud on RT-AC86U router. I did this for an experiment. I think nextcloud will not work with 512 mb memory. You need at least 1 GB or 2 GB. I have 1 GB RT-AC86U memory on my router.
I also increased the memory to 2 GB on the RT-AX88U and RT-AX86U routers. Probably easier to run nextcloud on raspberry pi
about increasing memory here
I have a ax86u pro it has 1gb
I have onedrive, this is just nice ,,
How about just setting up a scheduled rsync or some newer implementation, some with a GUI... Make backups of the things you need to make sure you have; email, contacts,, other in-app stuff and save files to the folder that's sync--probably schedule these...... Anyway, maybe NeXT cloud makes it possible, but seems difficult to get running and almost better to do OneDrive as you said--certainly ommits the maintenance.
