Asus RT-AC86U and Debian Bullseye + Nextcloud
asus ac86u
admin@asus:/tmp/home/root# opkg update
Downloading http://bin.entware.net/aarch64-k3.10/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
do you use merlin firmware?
you need install armhf - i think (not arm64)
debootstrap --arch=armhf bullseye /opt/debian/ http://ftp.debian.org/debian/
print command here
opkg list-installed
may be need install busybox
opkg install busybox
asus ac86u
print command here
opkg list-installed
Yes, I'm running GNUton's Asus Merlin.
Installing BusyBox did the job!
Still trying to install arm64 one. But after extracting files for a while...
I: Extracting mount...
I: Extracting util-linux...
I: Extracting libxxhash0...
I: Extracting zlib1g...
W: Failure trying to run: chroot "/opt/debian" /bin/true
W: See /opt/debian/debootstrap/debootstrap.log for details
Ignored this error and moved on to the next few steps until:-
asus@ZenWiFi_XT8-6410:/tmp/home/root# debian enter
mount: /tmp/mnt/sda2/entware/debian/mnt: mount point does not exist.
       dmesg(1) may have more information after failed mount system call.
chroot: failed to run command ‘/bin/bash’: Exec format error
remove /opt/debian/ folder
Ummm, whole bunch of operation not permitted.
asus@ZenWiFi_XT8-6410:/tmp/mnt/sda2/entware# rm -r debian
rm: can't remove 'debian/dev/pts/0': Operation not permitted
rm: can't remove 'debian/proc/net': Operation not permitted
rm: descend into directory 'debian/proc/sys'? ^C
restart and try delete
or install new folder /opt/debian0
Managed to remove the old folder with debian stop .
You are right. Armhf is the one for my router. After all the stress Debian Bullseye has been installed sucessfully.
A minor error after entering debian tho.
bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8)
root@ZenWiFi_XT8-6410:/#
I found many fixes online but not sure which one to be applied to the router environment. Any idea?
Hi again,
What is the correct way of mounting extra folder(s) that function(s) the same as "EXT_DIR=/tmp/mnt/sda1/Media/" in your S99debian script?
I'm asking so becoz I can use rclone to mount a webdav folder to this EXT_DIR location, but not to EXT_DIR's subfolder (Media/Subfolder). Thing mounted via rclone to its subfolder cant be seen inside chroot. It's weird I dont know why...
Thanks.
my script
#!/bin/sh
PATH=/opt/bin:/opt/sbin:/sbin:/bin:/usr/sbin:/usr/bin
# Folder with Debian Jessie
CHROOT_DIR=/tmp/mnt/asus/entware/debian
# Some folder outside of sandbox,
# will be mounted to /mnt folder in Debian
# Uncommented "EXT_DIR=" line if you need to
# mount a folder inside debian (remove #)
# EXT_DIR=/tmp/mnt/sda1/Media/
EXT_DIR0=/tmp/mnt/4tb0
EXT_DIR1=/tmp/mnt/4tb1
EXT_DIR2=/tmp/mnt/4tb2
CHROOT_SERVICES_LIST=/opt/etc/chroot-services.list
if [ ! -e "$CHROOT_SERVICES_LIST" ]; then
    echo "Please, define Debian services to start in $CHROOT_SERVICES_LIST first!"
    echo "One service per line. Hint: this is a script names from Debian's /etc/init.d/"
    exit 1
fi
MountedDirCount="$(mount | grep $CHROOT_DIR | wc -l)"
start() {
    if [ $MountedDirCount -gt 0 ]; then
        echo "Chroot'ed services seems to be already started, exiting..."
        exit 1
    fi
    echo "Starting chroot'ed Debian services..."
    for dir in dev proc sys; do
        mount -o bind /$dir $CHROOT_DIR/$dir
    done
    [ -z "$EXT_DIR0" ] || mount -o bind $EXT_DIR0 $CHROOT_DIR/mnt/4tb0
    [ -z "$EXT_DIR1" ] || mount -o bind $EXT_DIR1 $CHROOT_DIR/mnt/4tb1
    [ -z "$EXT_DIR2" ] || mount -o bind $EXT_DIR2 $CHROOT_DIR/mnt/4tb2
    for item in $(cat $CHROOT_SERVICES_LIST); do
        chroot $CHROOT_DIR /etc/init.d/$item start
    done
stop() {
    if [ $MountedDirCount -eq 0 ]; then
        echo "Chroot'ed services seems to be already stopped, exiting..."
        exit 1
    fi
    echo "Stopping chroot'ed Debian services..."
        chroot $CHROOT_DIR /etc/init.d/$item stop
        sleep 2
    done
    umount /opt/debian/dev/pts
    mount | grep $CHROOT_DIR | awk '{print $3}' | xargs umount -l
restart() {
        echo "Chroot'ed services seems to be already stopped"
        start
    else
            sleep 2
        done
        echo "Restarting chroot'ed Debian services..."
        done
        done
    fi
enter() {
    mount -o bind /dev/ /opt/debian/dev/
    mount -o bind /dev/pts /opt/debian/dev/pts
    mount -o bind /proc/ /opt/debian/proc/
    mount -o bind /sys/ /opt/debian/sys/
    chroot /opt/debian /bin/bash
status() {
        echo "Chroot'ed services running..."
    else
        echo "Chroot'ed services not running!"
    fi
case "$1" in
start)
    start
stop)
    stop
restart)
    restart
enter)
    enter
status)
    status
    echo "Usage: (start|stop|restart|enter|status)"
    exit 1
esac
echo Done.
exit 0
my script
#!/bin/sh
    exit 1
fi
start() {
        exit 1
    fi
    done
    done
stop() {
        exit 1
    fi
        sleep 2
    done
restart() {
        start
    else
            sleep 2
        done
        done
        done
    fi
enter() {
status() {
    else
    fi
case "$1" in
start)
    start
stop)
    stop
restart)
    restart
enter)
    enter
status)
    status
    exit 1
esac
echo Done.
exit 0
Nice script template. Works perfectly for me.
Your nextcloud tutorial is so great that I managed to install it flawlessly.
However, Nextcloud warns me for no memory cache being configured. Do you use such cache to enhance performance too? For me it now always takes dozen seconds to load every page of nextcloud webui.
I tried opkg install redis-cli redis-server redis-utils' (outside chroot), but I dont know how to get the redis cache server to run in background, and connect it to the php7.4. This tutorial here seems to be relevant but I cant locate the utils/redis_init_script. Or do you use APCu or memcache?
Sorry to disturb you again mate.
512gb ram very little for nextcloud
For redis need more memory too
redis
sudo apt -y install redis-server
redis-server -v
systemctl status redis
sudo systemctl start redis-server
sudo systemctl enable redis-server
sudo apt -y install php-redis
php --ri redis
sudo phpenmod redis
sudo vi /var/www/nextcloud/config/config.php
'memcache.distributed' => '\OC\Memcache\Redis',
'memcache.local' => '\OC\Memcache\Redis',
'memcache.locking' => '\OC\Memcache\Redis',
'redis' => array(
     'host' => 'localhost',
     'port' => 6379,
sudo systemctl restart apache2 php7.4-fpm
redis
redis-server -v
php --ri redis
sudo phpenmod redis
'redis' => array(
     'port' => 6379,
Yup, I think it's a very bad idea to load up another cache server imposing further workload on the poor little thing. I'll take your advice not doing it :)
Transmission in chroot
cat /tmp/mnt/asus/entware/etc/init.d/S99ubuntu
#!/bin/sh
CHROOT_DIR=/tmp/mnt/asus/entware/ubuntu
CHROOT_SERVICES_LIST=/opt/etc/chroot-services-ubuntu.list
    exit 1
fi
start() {
        exit 1
    fi
    done
    done
stop() {
        exit 1
    fi
        sleep 2
    done
    umount /opt/ubuntu/dev/pts
restart() {
        start
    else
            sleep 2
        done
        done
        done
    fi
enter() {
    mount -o bind /dev/ /opt/ubuntu/dev/
    mount -o bind /dev/pts /opt/ubuntu/dev/pts
    mount -o bind /proc/ /opt/ubuntu/proc/
    mount -o bind /sys/ /opt/ubuntu/sys/
    chroot /opt/ubuntu /bin/bash
status() {
    else
    fi
case "$1" in
start)
    start
stop)
    stop
restart)
    restart
enter)
    enter
status)
    status
    exit 1
esac
echo Done.
exit 0
cat /tmp/mnt/asus/entware/etc/chroot-services-ubuntu.list
transmission-daemon
ubuntu enter
apt install transmission-daemon
vi /etc/init.d/transmission-daemon
USER=root
