Diversion slow down troubleshooting
foug
If Diversion is really slow down parts of my wired and wireless connection such as loading videos from reddit or imgur, where would I begin troubleshooting? I tried whitelisting the domains v.redd.it and img.redd.it and did not notice a change. Thanks.
Router: RT-AX86U Pro
What makes you conclude that Diversion is causing the issue?
When I disable it the issue goes away for my wired and wireless devices.
Does this issue happen instantly after enabling Diversion or after a few days? When it does start happening please check the router CPU....it might be getting hogged down depending on what other scripts (Skynet etc ..) you might be running.
