QuikSilver
Thanks that's what I figured...sneaky lil boogers.It’s not possible. Facebook delivers its ads on the same domain as everything else.
I added https://raw.githubusercontent.com/StevenBlack/hosts/master/alternates/social/hosts to the hosts lists in b and made sure the hosts files were updated. However, none of the Social Media sites are being blocked. The file has definitely been added, enabled, and updated (I had 10 hosts files, now I have 11.
That’s a lot of hosts files. Not very efficient. I stopped using his social block list because it can break websites. As far as I know it’s only meant to block social trackers and buttons but not block Facebook twitter and social media websites completely.... If you want to block them fully just manually blacklist Facebook.com etc
The blocklist.site only lists domains. This is not compatible with Diversion.Centralized hosts file i use for information :
https://blocklist.site/app/
https://github.com/AdroitAdorKhan/Energized
diversion restartPerhaps you know itthis morning when I woke up, the internet didn’t work anymore. I had WiFi, but DNS didn’t work. I rebooted the router and everything worked again.
How can I restart Diversion? Then I can test the restart if it happens again.
Did either of you try anything other than DNS? Such as 'ping 1.1.1.1' from an SSH session to see if it was just a DNS issue or a connection issue?The same thing happened to me over a week ago. Im not sure what caused it. Besides Diversion I was also running skynet and stubby. The syslog showed nothing unusual.
Do you run stubby?
Same thing happened to us, but it was our ISP, not our router. Might not have realized it if we weren't up WAAAAAYYYYYY too late. Internet and our phones went out (our phones are VoIP through the ISP's modem), and although the phone returned, we still had no internet access (i.e. ping didn't work either). Dunno if waiting would have eventually fixed it or not, but rebooting the router did.
Okay, likely not possible for that to be a Diversion (or Stubby) problem then, since ping is entirely separate from those. It's possible the WAN IP shown in the webgui was a holdover from the last IP it was addressed. I think mine initially showed the WAN IP before it finally realized it didn't have connection. If you have Administration -> System -> Network Monitoring turned off completely I'm not sure that the router could determine that it didn't have an internet connection. I leave network monitoring on, ping to 1.1.1.1.100% packet loss. With solid light on modem showed had line sync to ISP. WebGUI showed router had been assigned WAN IP by the ISP. Just no internet connections worked. Pings to 1.1.1.1 from clients failed. Using router network tools to ping 1.1.1.1 or 8.8.8.8 failed too.
I have whitelisted onedrive.live.com in diversion, however its still being blocked in the blacklist. Tried adding it to the whitelist again, it says "onedrive.live.com is already in the whitelist", processing all lists doesn't fix the problem, I have to use a vpn or disable diversion. Any ideas?
What blocking list are you using? Works fine here.I have whitelisted onedrive.live.com in diversion, however its still being blocked in the blacklist. Tried adding it to the whitelist again, it says "onedrive.live.com is already in the whitelist", processing all lists doesn't fix the problem, I have to use a vpn or disable diversion. Any ideas?
https://someonewhocares.org/hosts/zero/hosts
http://winhelp2002.mvps.org/hosts.txt
https://pgl.yoyo.org/adservers/serverlist.php?hostformat=hosts&showintro=0&mimetype=plaintext&useip=192.168.50.2
https://hosts-file.net/ad_servers.txt
http://www.malwaredomainlist.com/hostslist/hosts.txt
https://hosts-file.net/emd.txt
https://hosts-file.net/exp.txt
https://hosts-file.net/hjk.txt
https://hosts-file.net/mmt.txt
https://hosts-file.net/psh.txt
https://raw.githubusercontent.com/crazy-max/WindowsSpyBlocker/master/data/hosts/spy.txt
https://raw.githubusercontent.com/WindowsLies/BlockWindows/master/hosts
I’d completely overlooked this setting (network monitoring) all these years! So, in practice, how does it work? If all’s well, I guess nothing of significance happens, but if it detects a failure to reach the dns server or a failure to receive a ping response, what happens then? Some sort of alert, or just a syslog entry? Or perhaps a ‘phone call from Merlin to tell me my network’s down and suggestions as to what to check?Okay, likely not possible for that to be a Diversion (or Stubby) problem then, since ping is entirely separate from those. It's possible the WAN IP shown in the webgui was a holdover from the last IP it was addressed. I think mine initially showed the WAN IP before it finally realized it didn't have connection. If you have Administration -> System -> Network Monitoring turned off completely I'm not sure that the router could determine that it didn't have an internet connection. I leave network monitoring on, ping to 1.1.1.1.
Welcome To SNBForums
