The file sd.png is too small to read anything.
curl https://files.ftscraft.de/file/ELR.txt
0.0.0.0 149.202.170.60
0.0.0.0 23.129.64.101
0.0.0.0 37.187.129.166
0.0.0.0 77.247.181.162
0.0.0.0 91.146.121.3
0.0.0.0 217.115.10.131
0.0.0.0 204.17.56.42
https://files.ftscraft.de/file/ELR.txt does not have hostnames, just 0.0.0.0 and IP addresses.
Code:curl https://files.ftscraft.de/file/ELR.txt 0.0.0.0 149.202.170.60 0.0.0.0 23.129.64.101 0.0.0.0 37.187.129.166 0.0.0.0 77.247.181.162 0.0.0.0 91.146.121.3 0.0.0.0 217.115.10.131 0.0.0.0 204.17.56.42
Yeah, IP to IP blocking does not work in Diversion. Use Skynet for such tasks.But adaway.org/hosts.txt not. I set bittorrent.com on my blacklist and it doesn't work. Btw I had freshtmato on the router before and I could block everything. Why not Diversion here?
0.0.0.0 domain.com
127.0.0.1 otherdomain.com
Diversion ONLY works with an IP-host pair and there's no way around it. Dnsmasq does not do that.
See https://diversion.ch/diversion/use/blocking-file-hosts-files.html
Again, the IP part MUST be either 0.0.0.0 or 172.0.0.1:
Code:0.0.0.0 domain.com 127.0.0.1 otherdomain.com
Works perfect, just make sure you add the https domain: https://adaway.org/hosts.txtstrangely enough the adaway hosts list doesn't work for me
see for yourself: adaway.org/hosts.txt
Ok, how do you explain this to me? I use this blocklist too (https://hosts-file.net/ad_servers.txt) and I can ping these page http://www.ngbn.net/ . Why isn't this page blocked? This page is included in the blocklist
Pinging isn't a good test - Diversion causes dnsmasq to resolve the blocked domain to another IP (127.0.0.1 for example will mean the client pings itself)Ok, how do you explain this to me? I use this blocklist too (https://hosts-file.net/ad_servers.txt) and I can ping these page http://www.ngbn.net/ . Why isn't this page blocked? This page is included in the blocklist
Of course you can ping it. The response comes from your router. How else should router adblocking work LAN wide?Ok, how do you explain this to me? I use this blocklist too (https://hosts-file.net/ad_servers.txt) and I can ping these page http://www.ngbn.net/ . Why isn't this page blocked? This page is included in the blocklist
Set pixelserv IP to 192.168.1.2 since .3 is in DHCP pool.Help me out on upgrading to Diversion standard....
Current
LAN - DHCP Server:
IP Pool Starting Address 192.168.1.2
IP Pool Ending Address 192.168.1.254
Enable Manual Assignment Yes (I've about 20 manually assigned IP within 192.168.1.201 to 192.168.1.235)
Now when trying to upgrade from Lite to standard, its asking to change IP Pool Starting Address to 192.168.1.3
After
LAN - DHCP Server:
IP Pool Starting Address 192.168.1.3
but when I enter 192.168.1.3 for pixelserv, it kept telling me 192.168.1.3 not an assigned reserved IP? what did I do wrong?
You've not completely read the instructions thenHelp me out on upgrading to Diversion standard....
Current
LAN - DHCP Server:
After
LAN - DHCP Server:
Meanwhile it works, thank you for your support! But since the installation my bandwith decreased from 904mbps to 400mbps. Can anyone help me to fix this?Of course you can ping it. The response comes from your router. How else should router adblocking work LAN wide?
Edit: Can you open the page in a browser?
They are. You should see some Diversion, Entware and pixelserv-tls messages in the syslog when the router starts up or you change settings.Thanks visortgw & thelonelycoder, got it working now!
pixelserv-tls IP would be 192.168.1.2
Current
LAN - DHCP Server:
Enable Manual Assignment Yes (about 20 manually assigned IP within 192.168.1.201 to 192.168.1.235)
My current LAN- DHCP Server: - settings correct?
That has to be 'house made'. Installing Diversion does not change your bandwidth at all nor does it change any relevant settings that would impact throughput of your router.Meanwhile it works, thank you for your support! But since the installation my bandwith decreased from 904mbps to 400mbps. Can anyone help me to fix this?
CTF is activated
Current
LAN - DHCP Server:
After
LAN - DHCP Server:
Welcome To SNBForums
