Skeptical.me
Welcome
This is Diversion - the Router Adblocker for Asuswrt-Merlin
AB-Solution is now Diversion
All install and update info, as well as other useful information is on the Diversion website.
September 9, 2018
Diversion 4.0.1 is now available
See this post or the website for the change log
Diversion is free to use under the GNU General Public License version 3 (GPL-3.0).
If you like Diversion and find it useful, you can help it's further development with a donation.
Thank you!
To see the fancy ticks and crosses that Diversion shows during operations, make sure your SSH terminal encoding is set to UTF-8.
Diversion is interactive. To start the Diversion UI after installation, use
For quick operation options without starting the UI, useCode:diversion
to make yourself familiar with the available options.Code:diversion help
Screenshots of Diversion 4.0, standard and extended menu (more options o)
I understand for my new ASUS RT-AC86U I have to create a Linux compatible USB Drive in order to install and run this on my router, is that correct? I did have debian installed on a PC but I no longer do, is it possible to format my 32GB USB Drive using a Windows PC or a Mac (I don't think I can with a Mac)? And if so what's required of me to get the USB drive compatible? I suppose I can use Parallels 14 to install a Linux Distro and create one, but I've not done it before, and I'm not sure what I specifically need to do to make it compatible for this specific router as I understand there are a few Linux formats for drives, is that true?
