That line is from the install routine.Tried to enable and update, but now I get this line repeated many times:
Code:Waiting for blockinglist entry...
diversion mount
> diversion mount
____ _ _
| _ \(_)_ _____ _ __ ___(_) ___ _ __
| | | | \ \ / / _ \ '__/ __| |/ _ \| '_ \
| |_| | |\ V / __/ | \__ \ | (_) | | | |
|____/|_| \_/ \___|_| |___/_|\___/|_| |_|
Welcome
This is Diversion 4.1.10
i Enter 'diversion help' for more options
✔ No change: Diversion is enabled
I couldn't find minimal as a choiceNew predefined blocking list "Minimal" in b to choose from
___________________________________________________
What do you want to do? b
Blocking list options
The blocking list is assembled from hosts file(s)
and is the main ad-blocker in Diversion.
To fine tune the blocking list, use the edit list
options in el .
1. Change composition Standard fs
2. Disable + Plus hosts
3. Change update day(s) and time
4. Update blocking list now bu
5. Find domain in hosts file(s)
6. Alternate blocking list for specified clients
7. Use LAN blocking IP address (advanced setting)
8. Domains per line in blocking list(s), 20
Enter selection [1-8 e=Exit] 1
____________________________________________________
1. Select a predefined list
2. Customize hosts list
3. Enable blocking list fast switch fs
Enter your selection: [1-3 e=Exit] 1
Select predefined blocking list to use.
Your current type is Standard+
1. Minimal
winhelp2002.mvps.org.
Blocks ads and badware only.
Filesize: ~220 KB, ~10,800 blocked domains.
2. Small
someonewhocares.org, pgl.yoyo.org,
github.com/hoshsadiq/adblock-nocoin-list.
Restricted blocking of Ads.
Filesize: ~340 KB, ~17,600 blocked domains.
3. Standard
github.com/StevenBlack adware + malware.
Good mix of blocked domains.
Filesize: ~840 KB, ~43,000 blocked domains.
4. Medium
github.com/StevenBlack adware + malware,
hosts-file.net/ad_servers.txt.
Comprehensive list of blocked domains.
Filesize: ~2 MB, ~83,000 blocked domains.
5. Large
hosts.oisd.nl
Very well maintained large hosts file, see
reddit.com/r/pihole/comments/bppug1/introducing_the/
Filesize: ~21 MB, ~953,000 blocked domains.
i Plus hosts + are enabled.
https://hosts-file.net/emd.txt, exp.txt, hjk.txt,
mmt.txt and psh.txt are separately added.
What an incredibly useful feature, this guy should get some kind of award for this (Diversion).b,1,1 from the main Diversion menu.
For some reason, when using minimal list, it's showing as custom everywhere.Diversion 4.1.10 is now available
What's new in Diversion 4.1.10
- Added u for Diversion update check to main menu.
- Uses built-in openssl binary for encrypting/decrypting email password. Thanks @kernol for reporting.
- Removed "export PATH=/sbin:/bin:/usr/sbin:/usr/bin:$PATH" line in all files, same as amtm since v3.0.0.
- el and b accept non-Unix End-of-line EOL remote files.
- Does not use temporary pgl.yoyo.org file while updating when blocking list(s) are below 1050KB in size.
- New predefined blocking list "Minimal" in b to choose from, uses winhelp2002.mvps.org.
- Domains per line (dpl) setting in blocking list(s) is no longer a hidden setting in b. Auto updates blocking list(s) if change is detected.
- Fixed near match(es) search in el by requiring above setting to be 1 domain per line.
- Reviewed hard coded SNB whitelist, thanks @dave14305 for tagging me. See the new list at https://diversion.ch/diversion/use/hard-coded-whitelist.html
- Swap file size selection and removal now in sync with amtm and Skynet functions.
- No change of default blocking list setting "Standard" for new installs, thanks all for your posted opinions.
- Fixed no bugs, did not improve performance, donated @martinr's "newborn" donation to Terre des Hommes and I'm going on a vacation someplace nice tomorrow. See ya!
How to update
Use u to update to this latest version.
Maybe because I have a whitelist hosted?
On main menu and on "b".What do you mean with everywhere?
How useful is it to look at stats?
For my use it's a 'set it and forget it' type of thing.
Red: blockedCan anyone tell me what the various colours signify when following the log in real time? Obviously, the red entries are blocked traffic, but what about the yellows, greens, blues and pale grey entries?
Welcome To SNBForums
