That last line in your code box says otherwise?![]()
Diversion upgrade log Sun, 12 Apr 2020 01:33:31 +0800
[31m____________________________________________________[0m
[42m i [0m Checking router
[42m ✔ [0m Asuswrt-Merlin
[42m ✔ [0m Wireless router mode
[42m ✔ [0m dos2unix
[42m ✔ [0m Netstat
[42m ✔ [0m Compatible device(s)
[42m ✔ [0m Internet
[42m ✔ [0m NTP date is synced
[42m i [0m Router check complete
[42m i [0m Checking dnsmasq.conf.add entries
[42m ✔ [0m dnsmasq.conf.add
[42m ? [0m Select Diversion Edition to upgrade to
[90m 1. Diversion Lite SSH UI, Entware,
blocks only http ads[0m
2. Diversion Standard SSH UI, Entware,
package pixelserv-tls,
blocks http and https ads[0m
Select Edition [2-2 e=Exit]
[42m i [0m Checking port 443 availability
[42m ✔ [0m Port 443 is available
[42m i [0m Reserving one IP address for pixelserv-tls
[42m ! [0m DO THIS NOW: Log into this routers WebUI
- Go to LAN > DHCP Server
- Adjust "IP Pool Starting Address" from the
standard xxx.xxx.xxx.2 (typically 192.168.1.2)
to xxx.xxx.xxx.3 (e.g 192.168.1.3)
(xxx.2 would be the reserved address)
- Make sure the reserved address is not used
by your other devices
- Then click "Apply"
You will need to enter the IP address next
[42m ! [0m Press Enter to continue when ready
Enter pixelserv-tls IP Address:
[42m ✔ [0m 192.168.1.9 is a valid IP address
[42m i [0m checking if 192.168.1.9 is available to use
[42m ✔ [0m pixelserv-tls IP address set to 192.168.1.9
[42m i [0m Probing for Entware
[42m ✔ [0m Entware is already installed
[42m i [0m Getting Diversion Standard files
from diversion.ch
[42m ✔ [0m ash-history.div integrated
[42m ✔ [0m functions.div integrated
[42m ✔ [0m mount-entware.div integrated
[42m ✔ [0m post-conf.div integrated
[42m ✔ [0m rc.func.div integrated
[42m ✔ [0m rotate-logs.div integrated
[42m ✔ [0m S80pixelserv-tls integrated
[42m ✔ [0m update-bl.div integrated
[42m ✔ [0m write-config.div integrated
[42m i [0m Checking white and blacklists
[42m ✔ [0m Whitelist
[42m ✔ [0m Blacklist
[42m ✔ [0m Wildcard blacklist
[42m i [0m Probing for pixelserv-tls
[42m i [0m Installing Entware package 'pixelserv-tls'
[90m
Place ca.crt and ca.key to /opt/var/cache/pixelserv before starting HTTPS mode.
Start options can be adjusted via /opt/etc/init.d/S80pixelserv-tls.
See 'pixelserv-tls -h' for details
Installing pixelserv-tls (2.3.1-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/pixelserv-tls_2.3.1-1_armv7-2.6.ipk
Configuring pixelserv-tls.
[0m
[42m ✔ [0m pixelserv-tls installed
[42m i [0m Creating pixelserv-tls CA certificate
[90m
[0m
[42m ✔ [0m pixelserv-tls CA certificate created
[42m i [0m Checking /jffs/scripts entries
[42m ✔ [0m dnsmasq.postconf
[42m ✔ [0m services-stop
[42m ✔ [0m unmount (Diversion)
[42m ✔ [0m unmount (swap file)
[42m i [0m Initializing Diversion
[42m ✔ [0m blocking list
[42m i [0m Restarting Dnsmasq
[42m ✔ [0m Dnsmasq restarted
[42m i [0m Checking dnsmasq.conf entries
[42m ✔ [0m Additional hosts
[42m ✔ [0m Log facility
[42m i [0m (Re)starting pixelserv-tls
[90m
Starting pixelserv-tls (Diversion)... failed
[0m
[41m ✖ [0m pixelserv-tls not running, restarting...
[90m
Starting pixelserv-tls (Diversion)... done
[0m
[41m ✖ [0m pixelserv-tls not running, check Syslog for errors
[42m ! [0m Press Enter to acknowledge
[42m i [0m Checking cron jobs
[42m ✔ [0m cron file found
[42m ✔ [0m blocking list update
[42m ✔ [0m Rotate logs
[42m ✔ [0m Ads counter
[42m ✔ [0m Diversion Standard v4.1.11 upgrade complete
Install log is a static report - from the past. Not sure where you see the GUI showing pixelserv-tls not running?
with minimal blocking list I can log in to Android PayPal app and I haven't seen ads, very happy.I switched to small list and now I can log-in to PayPal. The only downside is that some ads are now being shown.
I use the Standard list and have never had an issue with PayPalwith minimal blocking list I can log in to PayPal and I haven't seen ads, very happy.
Sent from my SM-G970F using Tapatalk
@Ro berto the problem isn't with paypal per-say, I have noticed issues with many financial login sites that had "additional security logins". the issues don't seem to occur for me if i skip "additional security step login" parameters. note: diversion has the option to whitelist as well.I use the Standard list and have never had an issue with PayPal
In the d menu in Diversion.My uiDivstats is showing 406% blocked. Can someone please tell me where the actual logfile is located so that I can scrub it and start from fresh?
The encryption is only from Stubby out to the internet to your chosen DoT servers. The DNS traffic from your LAN to dnsmasq and dnsmasq to Stubby is not encrypted. Diversion works within dnsmasq, so it is logging the queries before they are encrypted.Diversion is working flawlessly in my AC86U with 384.16 merlin FW installed but I have a question about DoT, which I am using. I am still being able to see all queries from Dnsmasq on SSH client, on Diversion. Pardon me if this is an obvious one but should'nt it be encrypted and not visible from the log?
Thanks in advance.
No, that device runs its own VPN, circumventing the router. However, other devices behind the router and using it as the DNS resolver still use Diversion.Today, I managed to get WireGuard running with 1.1.1.1 WARP on my local Windows 10 PC.
Do I still profit from adblocking through Diversion on my router? Or is this now being somehow circumvented due to WireGuard?
I cannot wrap my head around this.
Welcome to the forum. Can you tell us exactly what the error message says in Adobe Lightroom?Hi! First i have to say thank you for your work, i love having the addblocking in my router. Now, I have one question that I hope someone can solve. I use adobe lightroom and if I have diversion active, it gives me an error and it closes. How can I avoid this? Sorry if it is a dumb question, but I´m not an expert...Thank you
Thanks. I have no idea what that Spanish says, but before I give you a link, which explains how to whitelist a site in Diversion, do stop and consider: is there a genuine reason why Diversion is blocking that site? Before whitelisting any site, I’d want to be 100% certain that it really was a false positive. (I assume you know why the error message is in Spanish.)I´ve done a screenshot, the only problem is that is in Spanish...but maybe it´s enough. When the program loads, I get that error and it closes. If I disable diversion, it works perfectly and I get no error
We use essential cookies to make this site work, and optional cookies to enhance your experience.
