Diversion Diversion - the Router Ad-Blocker
Hello everyone. Thank you so much for diversion. This is a great thing but unfortunately I have a problem because it doesn't work for me (that's my impression)
I have installed the last stable version of asuswrt-merlin on ac68u. I installed diversion, unbound and skynet with amtm. Skynet and unbound work great but diversion does not. For diversion, I chose the standard version from pixelserver. For pixelserver I chose ip 192.168.1.2. On the DHCP router numbers from 192.168.1.3 so theoretically everything is ok. When I go to ip http://192.168.1.2/servstats I can see all the statistics from the pixelserver. The router settings are set to Enable DNS-based Filtering and Global Filter Mode - router. Nevertheless, advertisements appear on many websites, e.g. www.wp.pl and www.onet.pl. I will add that ad blocking does not work on any device connected to the lan or wifi network. Will anyone help to solve the problem?
Are your LAN DHCP Server DNS 1 and 2 fields blank? They must be.
My diversion with pixelserv-tls keeps failing. DNSMASq log shows inactive after reboots. clients don't properly get addresses with DHCP. I have to keep restarting diversion. My blocklist is about 2M domains.I am running this on an RT-AC5300.
Hi everyone. I have diversion (standard) on my RT-AX88U with the latest Merlin firmware 384.17. Yesterday was my first time installing any of the scripts so I am very new to all this. I discovered an issue soon after activating diversion. We use the CBS app on our phones to watch shows but when we click anything to watch it gives an error and won't load. Our account on there is one with ads. When I disable diversion the shows play just fine. So I figure the app gives the error because it can't serve us the ads. How do I figure out what sites to add to the whitelist in order for the CBS app to function correctly? Am I coming at this from the right direction? I have looked at the lists under the uiDivStats tab but I am still lost on how to proceed. I appreciate any help you fine folks can give. I am ready to learn more about using this now that I have it set up.
Have a look here:
https://www.snbforums.com/threads/diversion-the-router-ad-blocker.48538/page-69#post-446586
and
https://www.snbforums.com/threads/diversion-the-router-ad-blocker.48538/page-175#post-510105
but instead of following the log, as you have uiDivStats, you could run that on one device and watch the list (as you said) and then attempt to make your connection on another and then make a note of which domains are being blocked, then you can locate the appropriate one(s) by adding only them to the Diversion whitelist.
Have a look here:
and
Thank you for the info. I will see what I can figure out. :)
2 million domains in the blockinglist surely must be your problem. Your router runs out of memory.
Do you at least have a swap file set with sw in Diversion or amtm?
Here are my symptoms at 2 million domains. I have a swap defined. Lan devices fall off network. Aimesh instantly fall off sync. dhcp failure occurs. I have to say it has to be his use of 2 million domains.
Am I missing something .... I know that Diversion has been moved know under LAN tab.I just ignored that because I haven't restarted my router for a while and it was still showing under the addons tab.
Today I've noticed that the Diversion Tab under addon is not working anymore and I decided to reboot the router - still nothing under lan tab after this :mad:. After a few minutes i discovered the option to enable webUi for diversion ... did that but all I can see now is the Home tab with its menu options and after I can see the Test One and Test Two tabs but is nothing there ... it just says Testing One parameter ... and blank .. nothing there. Am I doing something wrong?
Can I still access Diversion statistics from WebUi like it was before?
Thank you.
Cheers
Thank you.
Cheers
You want to install uiDivStats (separate script).
Thank you Dave,
I had it already installed but it just needed a restart and update.
Everything woks fine now.
Still confused about Test 1 and Test 2 tabs as is nothing there :)
Thank you Dave,
Test 1 and Test 2 tabs are placeholders for the finished version of the (as yet unreleased) full GUI for Diversion.
Thank you Dave,
The Diversion WebUI (not to be confused with the third party app uiDivStats) is in beta mode, as is clearly stated when one enables the beta test. It's a test for functionability of some features and obviously not feature complete.
@thelonelycoder I just saw that updated Entware packages are available. Is it save to update?
after upgrading entware, i now have intermittent connection drops and ssh disconnects from router. time for a 2nd reboot
