wunage
The log says there is a bad block, that could be the problem.
May 5 07:05:34 syslogd started: BusyBox v1.25.1
May 5 07:05:34 kernel: klogd started: BusyBox v1.25.1 (2018-07-25 12:34:53 EDT)
May 5 07:05:34 kernel: itmask 0x1985 not found at 0x03980004: 0x0001 instead
May 5 07:05:34 kernel: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x03ea0018: 0x9b3d instead
May 5 07:05:34 kernel: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x03ea003c: 0xe270 instead
May 5 07:05:34 kernel: Cowardly refusing to erase blocks on filesystem with no valid JFFS2 nodes
May 5 07:05:34 kernel: empty_blocks 25, bad_blocks 1, c->nr_blocks 502
May 5 07:05:34 kernel: nand_erase_nand: attempt to erase a bad block at page 0x00008640
