thelonelycoder
Part of the Furniture
Probably is listening on all interfaces on that port, that's why it triggers it. Will look into it when time allows.Had a little install loop when fresh installing Diversion 4.0.6 today. I have modified my router's https port to listen on 443, but Diversion Standard would not install while that port was listening for httpd, even though Pixelserv would end up using a dedicated IP. I worked around it by temporarily stopping the httpd service, but I don't think the installer should block itself if 443 is active on the main router LAN IP.
Happy New Year!
Post the content of /jffs/scripts/post-mount, use sf to show the file.I keep losing my diversion install on router ugprade or reboot. What could be causing this? I've noticed I lose my ssh terminal command history when this happens as well
