[DIY] - SmallNetworks - Learning by Doing
sfx2000, thanks again for providing these posts and short tutorials to us and the world. I'll be sure to remember they are here if I'm in need of them for my customers.
Thanks for the kind comments - There is a method to the madness - frustrating perhaps for some, but when it's all put together - it'll blow a few minds, and make them ask why they're paying 300/400/500 dollars for a consumer grade router/AP, and we can do more with much less...
more flexibility, more capability, more security...
Sfx,
By following your tutorials and guidance, I´ve succeeded to install and auto-run the following services:
Samba
SSH
VNCServer
When I check the services with the "systemctl status <service>" command, the SSH and VNCServer services seems working while the Samba service reports to be inactive. However, Samba is working just fine, I can mount the share in Finder on my MacBook and access the shared directory on Ubuntu. Any thoughts on why "systemctl status" reports Samba to be inactive?
Ole
So with the writeup on samba, regarding @oletuv comment
sfx@raspy:~$ sudo systemctl status samba
● samba.service
  Loaded: masked (/dev/null; bad)
  Active: inactive (dead)
This is definitely something I need to sort out with systemd at some point, but sysv init is launching the samba, so all is good...
I suspect it's a unit definition to tell systemd that Samba is there...
Getting close - not quite done - cacti is proving to be a bit of a challenge to do a walk-thru as a guided tour - I use it quite a bit, but that years of experience, and having to see things from a new perspective without sitting next to someone saying click this and why...
Been doing most of the docs here on a small box - interesting what a bad CAT5 cable can do... see the Netgate and Turbo data... both are on the same switch - swapped the cable...
(both ends clipped off and put into the eWaste bucket)
Part 1 of 2 for remote access - this is ssh, part 2 of 2 is vnc
===== install/configure ssh =====
Let's sort ssh - we have lots of space, so let's use OpenSSH vs Dropbear
ssh back into the box - for me, I'm on a Mac, but remember I mentioned MobaXTerm - now's time to consider that if your Windows oriented... otherwise, putty also works fine for Windows
  ssh <username>@hostname.local
or
  ssh <username>@hostip
Note - Ubuntu has avahi installed - and mDNS is awesome... Win10 has mDNS, and iTunes installs mDNS/Bonjour for older versions of Windows - if avahi isn't working, then install it
  sudo apt-get install avahi-daemon
You'll appreciate this later... now tweaking the ssh...
  cd /etc/ssh
Note - most of the defaults are fine, so we'll hit the high points
edit the /etc/sshd_config - save a copy first -
  sudo cp sshd_config sshd_config.bak
and then
  sudo nano /etc/ssh/sshd_config
edit/change the following:
  LogLevel VERBOSE
  LoginGraceTime 30
  PermitRootLogin no
  MaxAuthTries 3
  X11Forwarding no
  MaxStartups 2:30:10
add this line - this makes it so that only one person can login to SSH - <username> is the account you set up installing linux in the first place, and the one you're generally working with
  AllowUsers <username>
Save changes - restart ssh keep current session open
  sudo service ssh restart
Try to login to the ssh server again - should work, if not, check your edits...
Sfx,
I followed the SSH guidance on a fresh Ubuntu 16.04 install in VirtualBox (just for the purpose of practicing). Before saving a copy of and editing the "sshd_config" file I checked the /etc/ssh directory and only found the "ssh_config" file, which I believe is the configuration file for SSH client. I needed to install SSH Server by executing the "sudo apt-get install openssh-server" command, after which the "sshd_config" server configuration file was present in the /etc/ssh directory and I edited it according to your guidance. SSH is working well and auto-starting when Ubuntu boots up.
I´m not sure if there was something weird with my Ubuntu Desktop install in Parallels, but I just wanted to give this feedback/information.
Ole
You are correct...
ssh_config - this is the client config file where one can add particular options as needed
sshd_config - this is the config file for the openssh-server daemon - with Ubuntu Desktop, one has to add the openssh-server package, which adds the sshd_conf file, along with the daemon and the systemctl entry to launch at start
Nice to be running in a VM - as you can make a snapshot before making changes, and then if it doesn't work, you can go back to a working config. Very smart move. ;)
Probably 75 percent of what I'm working with while doing these writeups in in VMWare Workstation rather than on bare metal - I've got a couple of lower end units to make sure things work well enough - a RaspPI 2 for example, can do most of it, but there will be a couple of sections where it's not optimal.
You are correct...
Thanks for confirming. The ssh and samba services both work flawlessly now in my Ubuntu Desktop VM.
Absolutely, I currently have Ubuntu Desktop and Windows 10 Pro running in Parallels Desktop 11 and pfSense 2.3.2-DEVELOPMENT running in VirtualBox on my MacBook Pro.:)
Ole
++ Broadband
menu = Broadband
title = Broadband
host = 192.168.100.1
I don´t get any values in the graph here. What IP address should I put in this section?
++ SNB LBD Host
menu = SNB LBD Host
title = SNB LBD Host
host = hostname.local
I´m getting an "ERROR: /etc/smokeping/config.d/Targets, line 33: unknown section 'SNB LBD Host'" error. Fixed it by changing "++ SNB LBD Host" to "++ SNB-LBD-Host".
I suppose that "hostname.local" is the hostname of my Ubuntu server, e.g. "Parallels-Ubuntu.local"?
Ole
Put the IP of the device on the WAN port of your Router/AP - 192.168.100.1 is commonly used for cable modems, but it can be any IP address
Ole
hostname.local is a placeholder/example using mDNSResponder (e.g. Avahi), should be whatever the machine's name is - e.g Parellels-Ububtu.local is good if that is what the name is, otherwise can be an IP address
This all started as a loose collection of various notes I've gathered over the years...
As I've reviewed them, and prepped for documentation, there's a fair amount of rewrite to catch up with the current state of art. Some of those notes are over 15 years old... and people wonder why there are so many bugs in consumer Router/AP's.
I will be self-moderating and pulling some sections down (and I have been for a bit) - there's some errors, and some dependencies that if stepped thru in order, they all work.
Something to share though - as I've been verifying things, and putting it to the test - here's the server that's been doing the hard work ;)
Including the Storage Section which includes now LVM show and tell, RAID setup, and an extended SAMBA config...
I´m getting an 404 error.
The 404 or Not Found error message is an HTTP standard response code indicating that the client was able to communicate with a given server, but the server could not find what was requested.
Try going to http://hostip/phpmyadmin
Check your Apache2 logs - /var/log/apache2/error.log and /var/log/apache2/access.log along with /var/log/syslog
Yes, I know. All the other stuff works, except for phpmyadmin.
hostname = Parallels-Ubuntu
hostip = 192.168.10.15
http://parallels-ubuntu.local/ and http://192.168.10.15/ returns the default page.
http://parallels-ubuntu.local/lbd/index.html and http://192.168.10.15/lbd/index.html returns the "Blue Pill " page. :D
http://parallels-ubuntu.local/dokuwiki/install.php and http://192.168.10.15/dokuwiki/install.php returns the "DokuWiki Installer" page.
http://parallels-ubuntu.local/phpmyadmin and http://192.168.10.15/phpmyadmin returns the 404 "The requested URL /phpmyadmin was not found on this server" error message.
In /var/log/apache2/access.log:
192.168.10.157 - - [20/May/2016:09:20:22 +0200] "GET /phpmyadmin HTTP/1.1" 404 504 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_5) AppleWebKit/601.6.17 (KHTML, like Gecko) Version/9.1.1 Safari/601.6.17"
I´m pretty much stuck here. I´ve followed the steps/instructions in your excellent tutorial exactly, even reinstalled phpmyadmin a second time. I´m not sure what else to look for.
Anyhow, thank you so much for your contributions/tutorials in this thread. I enjoy this stuff a lot!
Kind regards,
Ole
When installing from apt, you get a screen that asks which http server is being used..
When that first prompt appears, apache2 is highlighted, but not selected.
If you do not hit Space to select Apache, the installer will not move the necessary files during installation. Hit Space, Tab, and then Enter to select Apache.
Sfx,
You are a genius! Thanks for your patience and for bearing over with me! That was it, phpmyadmin running flawlessly now. :)
Ole
Sfx,
I just noticed that you´ve pulled most of the tutorials. I know that you´re self-moderating this thread, so I hope your excellent tutorials will reappear soon. I like to redo these exercises several times for practicing and learning.
Sfx,
Yeah, as I've been reviewing them, they were a bit disconnected from each other - when done, I'll repost, in DokuWiki markup, so if you have DokuWiki installed, you can put them straight into your own DokuWiki and you'll have a long term copy ;)
SFX, I am confused by a couple of your previous edits where you state a post is reposted. I cannot find them at all. Am I missing something?
I have been following your thread and recently purchased a Rasberry Pi 3B looking forward to following along. -Thanks.
Please accept my apologies - as I was reviewing some of the sections, I found a few errors, and a lot of assumptions on my part about what the skill levels may be, so some of them, or at least some of the steps were a bit difficult.
I'm well into the rewrite - the storage section alone now is nearly 15 pages long - and is currently in a peer review with a couple of folks (helps to have another set of eyes to see inconsistencies and editorial errors)
All in all, the entire doc set is likely going to be 50 to 60 pages in length.
So be patient - the info will start flowing again soon - if not as posts inside the forum, I will make the information available again.
