Paulbaker1954
I have come across an issue with this router I can’t understand and I am not sure whether to raise this with ASUS OR PIA.
I have the router configured as main router connecting to SKY Fibre and all works fine.
Router is running std ASUS WRT Vesion 386 which is latest firmware.
OVPN client set up using PIA instructions and the config file includes the lines
dhcp-option DNS 10.0.0.241
dhcp-option DNS 10.0.0.243
When I activate the client all is ok, DNS works and my IP is a PIA One.
Now the issue is when I deactivate the VPN client I no longer have an assigned DNS server. I can ping IP addresses so I have a WAN connection just no DNS.
I have managed to work round by assigning 8.8.8.8 as the DNS server in the ASUS LAN setup and this works ok
I am curious as to why this occurs as it should not and don’t know if this is an ASUS or PIA Issue
