Dnscrypt from opendns
If you install entware you also can use transmission aka "download manager".
https://github.com/RMerl/asuswrt-merlin/wiki/Installing-Transmission-through-Entware
It's a win,win situation because with entware's transmission you will get a huge speed improvement
Just looking at these comments - which goes back as 2013 - my question is has Asus Download Master improved or is it Transmission better. I read some of the comments that stated 'Download Master' not able to do Magnet link which of course I can see within Download Master. I am in the same boat as @shooter40sw, like the idea of using dnscrypt without installing Entware -am Download Master is working OK - are there any main advantages of Entware?
thanks in advance
sammyano, I've compiled dnscrypt-proxy for asuswrt-merlin firmware. You may continue using DM or whatever you want:)
No Entware or Optware required, just follow these steps:
1) Make sure JFFS is enabled from WebUI, you need to reboot after enabling JFFS,
2) unpack archive from telnet/ssh console
wget -O - http://files.ryzhov-al.ru/Routers/asuswrt-merlin/dnscrypt-proxy/dnscrypt-proxy-asuswrt-merlin-mipsel.tgz | tar -C / -xvz
3) restart router.
Thanks ryzhov_al - so no other configuration required apart from the steps above right, lastly do I need to remove the Opendns IP specified within the router and will the above use opendns as default dnscrypt.
thanks again
followed the steps above and could not connect to the internet after installing - I have to manually delete all the scripts created to gain access again -
Jun 3 20:12:03 watchdog: start ddns.
Jun 3 20:12:03 rc_service: watchdog 343:notify_rc start_ddns
Jun 3 20:12:03 ddns update: ez-ipupdate: starting...
Jun 3 20:12:33 ddns update: error connecting to ns1.asuscomm.com:80
Jun 3 20:12:33 ddns update: asusddns_update: 1
Jun 3 20:12:48 rc_service: httpd 329:notify_rc restart_ddns
Jun 3 20:12:48 ddns: clear ddns cache file for server/hostname change
Jun 3 20:12:48 ddns update: ez-ipupdate: starting...
Jun 3 20:13:18 ddns update: error connecting to ns1.asuscomm.com:80
Jun 3 20:13:18 ddns update: asusddns_update: 1
Jun 3 20:13:33 watchdog: start ddns.
Jun 3 20:13:33 rc_service: watchdog 343:notify_rc start_ddns
Jun 3 20:13:33 ddns update: ez-ipupdate: starting...
Jun 3 20:14:03 ddns update: error connecting to ns1.asuscomm.com:80
Same for me!
Sent from my Galaxy Nexus using Tapatalk
Unfortunately, I do not using DDNS and\or any DNS filtering services, configured from WebUI.
I need to see full syslog, there must be some records when dnscrypt-proxy is starting.
Hi! thanks for the effort and great job!, I need to test this, I also have dns o matic, VPN, hop it works, I will send the results as soon as I test.
ryzhov_al - will check the syslog for when dnscrpt-proxy started. I was completed locked out of internet connection by running the command
Hi, I just run the script, I dont loose internet access, but it does not update the dns-o-matic. At first reboot it did not do NTP either but after the second one it did. Thanks
Dec 31 20:00:11 dnsmasq[309]: started, version 2.69 cachesize 1500
Dec 31 20:00:11 dnsmasq[309]: warning: interface tun21 does not currently exist
Dec 31 20:00:11 dnsmasq[309]: warning: ignoring resolv-file flag because no-resolv is set
Dec 31 20:00:11 dnsmasq[309]: asynchronous logging enabled, queue limit is 5 messages
Dec 31 20:00:11 dnsmasq-dhcp[309]: DHCP, IP range 172.17.1.5 -- 172.17.1.30, lease time 1d
Dec 31 20:00:11 dnsmasq[309]: using nameserver 127.0.0.1#65053
Dec 31 20:00:11 dnsmasq[309]: read /etc/hosts - 10 addresses
Dec 31 20:00:11 dnsmasq[309]: read /etc/hosts.dnsmasq - 3 addresses
Dec 31 20:00:11 dnsmasq-dhcp[309]: read /etc/ethers - 3 addresses
Dec 31 20:00:11 WAN Connection: ISP's DHCP did not function properly.
Dec 31 20:00:11 dropbear[313]: Running in background
Dec 31 20:00:11 RT-N66U: start httpd
Dec 31 20:00:12 syslog: Generating SSL certificate...
Dec 31 20:00:12 crond[324]: crond: crond (busybox 1.20.2) started, log level 8
Dec 31 20:00:14 disk monitor: be idle
Dec 31 20:00:14 Samba Server: daemon is started
Dec 31 20:00:15 dnsmasq[309]: read /etc/hosts - 10 addresses
Dec 31 20:00:15 dnsmasq[309]: read /etc/hosts.dnsmasq - 3 addresses
Dec 31 20:00:15 dnsmasq-dhcp[309]: read /etc/ethers - 3 addresses
Dec 31 20:00:45 dnsmasq[309]: read /etc/hosts - 10 addresses
Dec 31 20:00:45 dnsmasq[309]: read /etc/hosts.dnsmasq - 3 addresses
Dec 31 20:00:45 dnsmasq-dhcp[309]: read /etc/ethers - 3 addresses
Dec 31 20:00:45 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Dec 31 20:00:45 dnsmasq[309]: exiting on receipt of SIGTERM
Dec 31 20:00:45 dnsmasq[413]: started, version 2.69 cachesize 1500
Dec 31 20:00:45 dnsmasq[413]: warning: interface tun21 does not currently exist
Dec 31 20:00:45 dnsmasq[413]: warning: ignoring resolv-file flag because no-resolv is set
Dec 31 20:00:45 dnsmasq[413]: asynchronous logging enabled, queue limit is 5 messages
Dec 31 20:00:45 dnsmasq-dhcp[413]: DHCP, IP range 172.17.1.5 -- 172.17.1.30, lease time 1d
Dec 31 20:00:45 dnsmasq[413]: using nameserver 127.0.0.1#65053
Dec 31 20:00:45 dnsmasq[413]: read /etc/hosts - 10 addresses
Dec 31 20:00:45 dnsmasq[413]: read /etc/hosts.dnsmasq - 3 addresses
Dec 31 20:00:45 dnsmasq-dhcp[413]: read /etc/ethers - 3 addresses
Dec 31 20:00:45 wan-start: started [0]
Dec 31 20:00:45 rc_service: service 418:notify_rc restart_ntpc
Dec 31 20:00:45 syslog: Resolver information required.
Dec 31 20:00:45 syslog: The easiest way to do so is to provide a resolver name.
Dec 31 20:00:45 syslog: Example: dnscrypt-proxy -R mydnsprovider
Dec 31 20:00:45 syslog: See the file [/home/ryzhovau/projects/staging-mips/share/dnscrypt-proxy/dnscrypt-resolvers.csv] for a list of compatible public resolvers
Dec 31 20:00:45 syslog: The name is the first column in this table.
Dec 31 20:00:45 syslog: Alternatively, an IP address, a provider name and a provider key can be supplied.
Dec 31 20:00:45 syslog: Please consult http://dnscrypt.org and the dnscrypt-proxy(8) man page for details.
Dec 31 20:00:45 kernel: nf_conntrack_rtsp v0.6.21 loading
Dec 31 20:00:45 kernel: nf_nat_rtsp v0.6.21 loading
Dec 31 20:00:45 rc_service: udhcpc 392:notify_rc stop_upnp
Dec 31 20:00:45 rc_service: udhcpc 392:notify_rc start_upnp
Dec 31 20:00:45 miniupnpd[458]: HTTP listening on port 38834
Dec 31 20:00:45 miniupnpd[458]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 31 20:00:45 ddns: clear ddns cache file for server/hostname change
Dec 31 20:00:45 ddns update: ez-ipupdate: starting...
Dec 31 20:00:47 WAN Connection: WAN was restored.
Dec 31 20:00:50 nmbd[369]: [2010/12/31 20:00:50, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(392)
Dec 31 20:00:50 nmbd[369]: Samba name server ORION is now a local master browser for workgroup ANTARES on subnet 172.17.1.1
Jun 4 19:38:21 rc_service: ntp 419:notify_rc restart_upnp
Jun 4 19:38:21 rc_service: ntp 419:notify_rc restart_diskmon
Jun 4 19:38:21 rc_service: waitting "restart_upnp" via ntp ...
Jun 4 19:38:21 miniupnpd[458]: shutting down MiniUPnPd
Jun 4 19:38:22 miniupnpd[468]: HTTP listening on port 33664
Jun 4 19:38:22 miniupnpd[468]: Listening for NAT-PMP/PCP traffic on port 5351
Jun 4 19:38:22 ddns update: error connecting to updates.dnsomatic.com:80
Jun 4 19:38:22 ddns update: asusddns_update: 1
Jun 4 19:38:22 disk monitor: be idle
Jun 4 19:38:22 rc_service: udhcpc 392:notify_rc start_vpnserver1
Jun 4 19:38:22 dhcp client: bound XXX.XXX.XXX.XXX via XXX.XXX.0.1 during 3600 seconds.
Jun 4 19:38:22 kernel: tun: Universal TUN/TAP device driver, 1.6
Jun 4 19:38:22 kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Jun 4 19:38:23 kernel: device tun21 entered promiscuous mode
Jun 4 19:38:26 openvpn[481]: OpenVPN 2.3.4 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on May 9 2014
Jun 4 19:38:26 openvpn[481]: library versions: OpenSSL 1.0.0j 10 May 2012, LZO 2.06
Jun 4 19:38:26 openvpn[481]: PLUGIN_INIT: POST /usr/lib/openvpn-plugin-auth-pam.so '[/usr/lib/openvpn-plugin-auth-pam.so] [openvpn]' intercepted=PLUGIN_AUTH_USER_PASS_VERIFY
Jun 4 19:38:26 openvpn[481]: Diffie-Hellman initialized with 512 bit key
Jun 4 19:38:26 openvpn[481]: Socket Buffers: R=[118784->131072] S=[118784->131072]
Jun 4 19:38:26 openvpn[481]: TUN/TAP device tun21 opened
Jun 4 19:38:26 openvpn[481]: TUN/TAP TX queue length set to 100
Jun 4 19:38:26 openvpn[481]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Jun 4 19:38:26 openvpn[481]: /usr/sbin/ip link set dev tun21 up mtu 1500
Jun 4 19:38:26 openvpn[481]: /usr/sbin/ip addr add dev tun21 local 10.8.0.1 peer 10.8.0.2
Jun 4 19:38:26 openvpn[481]: /usr/sbin/ip route add 10.8.0.0/24 via 10.8.0.2
Jun 4 19:38:26 openvpn[490]: UDPv4 link local (bound): [undef]
Jun 4 19:38:26 openvpn[490]: UDPv4 link remote: [undef]
Jun 4 19:38:26 openvpn[490]: MULTI: multi_init called, r=256 v=256
Jun 4 19:38:26 openvpn[490]: IFCONFIG POOL: base=10.8.0.4 size=62, ipv6=0
Jun 4 19:38:26 openvpn[490]: Initialization Sequence Completed
Jun 4 19:38:48 watchdog: start ddns.
Jun 4 19:38:48 rc_service: watchdog 334:notify_rc start_ddns
Jun 4 19:38:48 ddns update: ez-ipupdate: starting...
Jun 4 19:39:07 crond[324]: time disparity of 1801418 minutes detected
Jun 4 19:39:18 ddns update: error connecting to updates.dnsomatic.com:80
Jun 4 19:39:18 ddns update: asusddns_update: 1
Jun 4 19:39:48 watchdog: start ddns.
Jun 4 19:39:48 rc_service: watchdog 334:notify_rc start_ddns
Jun 4 19:39:48 ddns update: ez-ipupdate: starting...
Jun 4 19:40:18 ddns update: error connecting to updates.dnsomatic.com:80
Jun 4 19:40:18 ddns update: asusddns_update: 1
Jun 4 19:40:48 watchdog: start ddns.
I encountered this problem my first restart after upgrading the entware package.
I had to:
1) Create /opt/share/dnscrypt-proxy.csv
2) Populate it with https://raw.githubusercontent.com/jedisct1/dnscrypt-proxy/master/dnscrypt-resolvers.csv
3) Add the following to the init script's ARGS "-R opendns " (or insert your preferred resolver from the csv.
Hi, but I did not install entware, I used the script
wget -O - http://files.ryzhov-al.ru/Routers/a...roxy/dnscrypt-proxy-asuswrt-merlin-mipsel.tgz | tar -C / -xvz
That ryzhov al said, no need to install entware, just activate jffs. I have an R-66U using merlins latest firmware 42. Thanks!
What is the output of "/jffs/bin/dnscrypt-proxy --local-address=127.0.0.1:65053 --daemonize" in the shell?
Nothing at all
:/jffs/bin# ./dnscrypt-proxy --local-address=127.0.0.1:65053 --daemonize
:/jffs/bin#
and I keep getting this:
un 4 20:52:25 syslog: Resolver information required.
Jun 4 20:52:25 syslog: The easiest way to do so is to provide a resolver name.
Jun 4 20:52:25 syslog: Example: dnscrypt-proxy -R mydnsprovider
Jun 4 20:52:25 syslog: See the file [/home/ryzhovau/projects/staging-mips/share/dnscrypt-proxy/dnscrypt-resolvers.csv] for a list of compatible public resolvers
Jun 4 20:52:25 syslog: The name is the first column in this table.
Jun 4 20:52:25 syslog: Alternatively, an IP address, a provider name and a provider key can be supplied.
Jun 4 20:52:25 syslog: Please consult http://dnscrypt.org and the dnscrypt-proxy
Nothing at all
:/jffs/bin#
1) You need to create the dnscrypt-resolvers.csv file somewhere from https://raw.githubusercontent.com/jedisct1/dnscrypt-proxy/master/dnscrypt-resolvers.csv. (in /jffs is fine)
2)Run "ln -s /jffs/dnscrypt-resolvers.csv /home/ryzhovau/projects/staging-mips/share/dnscrypt-proxy/dnscrypt-resolvers.csv"
3) Add the above ln command to your wan-start before it starts dnscrypt-proxy.
Got it! No more default DNSCrypt servers are hardcoded. I've fixed Entware package, server is selectable now:
admin@RT-N66U:/tmp/mnt/OPT/tmp# opkg install dnscrypt-proxy
Installing dnscrypt-proxy (1.4.0-2) to root...
Configuring dnscrypt-proxy.
By default, dnscrypt-proxy will use the OpenDNS dnscrypt server.
You may choose another one if you wish:
1) cloudns-can (CloudNS Canberra)
2) cloudns-syd (CloudNS Sydney)
3) d0wn-fr-ns1 (First d0wn server in France)
4) d0wn-fr-ns2 (Second d0wn server in France)
5) d0wn-im-ns1 (d0wn server in Isle of Man)
6) d0wn-li-ns1 (d0wn server in Lichtenstein)
7) d0wn-nl-ns1 (First d0wn server in Netherlands)
8) d0wn-nl-ns2 (Second d0wn server in Netherlands)
9) d0wn-ro-ns1 (First d0wn server in Romania)
10) d0wn-ro-ns2 (Second d0wn server in Romania)
11) d0wn-sg-ns1 (d0wn server in Singapore)
12) dnscrypt.eu-dk (DNSCrypt.eu Denmark)
13) dnscrypt.eu-dk-ipv6 (DNSCrypt.eu Denmark over IPv6)
14) dnscrypt.eu-nl (DNSCrypt.eu Holland)
15) dnscrypt.eu-nl-ipv6 (DNSCrypt.eu Holland over IPv6)
16) okturtles (okTurtles)
17) opendns (OpenDNS)
18) opendns-familyshield (OpenDNS with FamilyShield)
19) opendns-ipv6 (OpenDNS over IPv6)
20) opennic-ca-ns3 (OpenNIC server ns3.ca)
21) opennic-ca-ns3-ipv6 (OpenNIC server ns3.ca over IPv6)
22) opennic-ca-ns4 (OpenNIC server ns4.ca)
23) opennic-ca-ns4-ipv6 (OpenNIC server ns4.ca over IPv6)
24) opennic-jp-ns2 (OpenNIC server ns2.jp)
25) opennic-jp-ns3-ipv6 (OpenNIC server ns3.jp over IPv6)
26) opennic-uk-ns10 (OpenNIC server ns10.uk)
27) opennic-uk-ns10-ipv6 (OpenNIC server ns10.uk over IPv6)
28) opennic-uk-ns8 (OpenNIC server ns8.uk)
29) opennic-uk-ns8-ipv6 (OpenNIC server ns8.uk over IPv6)
30) opennic-uk-ns9 (OpenNIC server ns9.uk)
31) opennic-uk-ns9-ipv6 (OpenNIC server ns9.uk over IPv6)
32) opennic-us-ca-ns17 (OpenNIC server ns17.ca.us)
33) opennic-us-ca-ns17-ipv6 (OpenNIC server ns17.ca.us over IPv6)
34) soltysiak (Soltysiak)
Choose server from list or hit Enter to continue [1-34]:
Will fix asuswrt-merlin's pre-compiled binaries+scripts later.
Precompiled binaries for asuswrt-merlin fixed too. To install DNSCrypt-proxy without Optware/Entware, please do:
2) Install precompiled dnscrypt binaries with start script from SSH/telnet console.
  • on MIPS-based routers (RT-N16, RT-N66U, RT-AC66U):
  • on ARM-based routers (RT-AC56U, RT-AC68U):
    wget -O - http://files.ryzhov-al.ru/Routers/asuswrt-merlin/dnscrypt-proxy/dnscrypt-proxy-asuswrt-merlin-arm.tgz | tar -C / -xvz
3) Reboot router.
The OpenDNS dnscrypt server will be used, if you wish to choose another one (from the list above), please install full package from Entware.
3) Reboot router.
Hi, Still not working,does not connect with the DNSOMATIC site
First Boot
I have internet access but:
No NTP
No DNSOMATIC
:/tmp/home/root# ps |grep dns
415 nobody 1028 S dnsmasq --log-async
524 xxxx 1236 S ez-ipupdate -S dnsomatic -i eth0 -h all.dnsomatic.com -u xxxxxx:************ -e /sbin/
529 xxxxx 1428 S grep dns
:/tmp/home/root# ps |grep dnscrypt
531 xxxxx 1428 S grep dnscrypt
:/tmp/home/root# ps |grep ntp
431 xxxxx 2468 S ntp
532 xxxxx 1052 S ntpclient -h time.windows.com -i 3 -l -s
533 xxxxx 1052 S ntpclient -h time.windows.com -i 3 -l -s
536 xxxxxx 1428 S grep ntp
Afer 10 minutes reboot
Dec 31 20:00:15 dnsmasq[415]: started, version 2.69 cachesize 1500
Dec 31 20:00:15 dnsmasq[415]: warning: interface tun21 does not currently exist
Dec 31 20:00:15 dnsmasq[415]: warning: ignoring resolv-file flag because no-resolv is set
Dec 31 20:00:15 dnsmasq[415]: asynchronous logging enabled, queue limit is 5 messages
Dec 31 20:00:15 dnsmasq-dhcp[415]: DHCP, IP range 172.17.1.5 -- 172.17.1.30, lease time 1d
Dec 31 20:00:15 dnsmasq[415]: using nameserver 127.0.0.1#65053
Dec 31 20:00:15 dnsmasq[415]: read /etc/hosts - 9 addresses
Dec 31 20:00:15 dnsmasq[415]: read /etc/hosts.dnsmasq - 3 addresses
Dec 31 20:00:15 dnsmasq-dhcp[415]: read /etc/ethers - 3 addresses
Dec 31 20:00:16 rc_service: service 428:notify_rc restart_ntpc
Dec 31 20:00:16 dnscrypt-proxy[432]: Starting dnscrypt-proxy 1.4.0
Dec 31 20:00:16 dnscrypt-proxy[432]: Initializing libsodium for optimal performance
Dec 31 20:00:16 dnscrypt-proxy[432]: Generating a new key pair
Dec 31 20:00:16 kernel: nf_conntrack_rtsp v0.6.21 loading
Dec 31 20:00:16 kernel: nf_nat_rtsp v0.6.21 loading
Dec 31 20:00:16 rc_service: udhcpc 391:notify_rc stop_upnp
Dec 31 20:00:16 rc_service: udhcpc 391:notify_rc start_upnp
Dec 31 20:00:16 ddns: clear ddns cache file for server/hostname change
ec 31 20:06:42 ddns update: error connecting to updates.dnsomatic.com:80
Dec 31 20:06:42 ddns update: asusddns_update: 1
Dec 31 20:07:12 watchdog: start ddns.
Dec 31 20:07:12 rc_service: watchdog 328:notify_rc start_ddns
Dec 31 20:07:12 ddns update: ez-ipupdate: starting...
Second reboot
Have Internet access
Have NTP dis the same thing yesterday, no NTP first boot, but second it worked.
No DNSOMATIC
31 20:00:15 dnsmasq[416]: warning: interface tun21 does not currently exist
Dec 31 20:00:15 dnsmasq[416]: warning: ignoring resolv-file flag because no-resolv is set
Dec 31 20:00:15 dnsmasq[416]: asynchronous logging enabled, queue limit is 5 messages
Dec 31 20:00:15 dnsmasq-dhcp[416]: DHCP, IP range 172.17.1.5 -- 172.17.1.30, lease time 1d
Dec 31 20:00:15 dnsmasq[416]: using nameserver 127.0.0.1#65053
Dec 31 20:00:15 dnsmasq[416]: read /etc/hosts - 10 addresses
Dec 31 20:00:15 dnsmasq[416]: read /etc/hosts.dnsmasq - 3 addresses
Dec 31 20:00:15 dnsmasq-dhcp[416]: read /etc/ethers - 3 addresses
Dec 31 20:00:15 dnscrypt-proxy[418]: Starting dnscrypt-proxy 1.4.0
Dec 31 20:00:15 dnscrypt-proxy[418]: Initializing libsodium for optimal performance
Dec 31 20:00:15 dnscrypt-proxy[418]: Generating a new key pair
Dec 31 20:00:16 rc_service: udhcpc 375:notify_rc stop_upnp
Dec 31 20:00:16 rc_service: udhcpc 375:notify_rc start_upnp
Dec 31 20:00:16 ddns update: ez-ipupdate: starting...
Dec 31 20:00:16 miniupnpd[459]: HTTP listening on port 53292
Dec 31 20:00:16 miniupnpd[459]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 31 20:00:16 WAN Connection: WAN was restored.
Jun 5 06:26:16 rc_service: ntp 419:notify_rc restart_upnp
Jun 5 06:26:16 rc_service: ntp 419:notify_rc restart_diskmon
Jun 5 06:26:16 rc_service: waitting "restart_upnp" via ntp ...
Jun 5 06:26:16 miniupnpd[459]: shutting down MiniUPnPd
Jun 5 06:26:16 miniupnpd[467]: HTTP listening on port 41495
Jun 5 06:26:16 miniupnpd[467]: Listening for NAT-PM
Jun 5 06:26:17 ddns update: error connecting to updates.dnsomatic.com:80
Jun 5 06:26:17 ddns update: asusddns_update: 1
Jun 5 06:26:17 disk monitor: be idle
Jun 5 06:26:17 rc_service: udhcpc 375:notify_rc start_vpnserver1
un 5 06:26:42 watchdog: start ddns.
That's strange. Mine is starting in one minute, works well.
I'm not using any dyndns services.
Now my WifI devices do not have internet. only if I specify the opendns servers on an iPad, but if i leave the router IP as the default gateway there is no internet, just found that out using a nexus 4 and it does not have internet, my ipad did have until I changed that option, and my PC does have internet because I have dnscrypt running as a service on my windows pc
Hi, I just tested again, and it fails to connect, my router the R 66U gets the IP from my ISP, already tried this with googles and opendns, I also had the DNS filter active for open DNS.
For this test I disabled DNS filtering, and let the ISP DNS servers
I installed the dns from the script, no entware... I have optware because I use download master.
After the installation of the script I reboot and my router does get an IP from my ISP, but no wireless on anything, if I place a DNS server like opendns on the ipad it works, but if a point to the router it does not.
My PC does the same, if I set the pc to get DNS automaticly, it loses internet conection, If I set it to use DNScrypt for windows, that I installed as a service for the PC it has internet connection.
So it looks like the script is not working for some reason, that nothing has internet service unless you bypass the routers DNS.
Thanks for your efforts!
Dec 31 20:00:44 dnsmasq[433]: using nameserver 127.0.0.1#65053
Dec 31 20:00:44 dnsmasq[433]: read /etc/hosts - 10 addresses
Dec 31 20:00:44 dnsmasq[433]: read /etc/hosts.dnsmasq - 3 addresses
Dec 31 20:00:44 dnsmasq-dhcp[433]: read /etc/ethers - 3 addresses
Dec 31 20:00:45 miniupnpd[460]: HTTP listening on port 35154
Dec 31 20:00:45 miniupnpd[460]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 31 20:00:45 dnscrypt-proxy[463]: Starting dnscrypt-proxy 1.4.0
Dec 31 20:00:45 dnscrypt-proxy[463]: Initializing libsodium for optimal performance
Dec 31 20:00:45 dnscrypt-proxy[463]: Generating a new key pair
un 5 12:47:09 ddns update: ez-ipupdate: starting...
Jun 5 12:47:39 ddns update: error connecting to updates.dnsomatic.com:80
Jun 5 12:47:39 ddns update: asusddns_update: 1
:/tmp/home/root# nslookup google.com
Server: 127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
433 nobody 1032 S dnsmasq --log-async
520 Scorpio 1236 S ez-ipupdate -S dnsomatic -i eth0 -h all.dnsomatic.com
According to log, dnscrypt-proxy starting as planned, but later it disappeared from process list. I can't reproduce such kind of behavior, sorry.
