DNScrypt dnscrypt installer for asuswrt
Trying now.
Still not working.
Going off memory:
Install dnscript
Resolve all dns queries
No ipv6
Manual setup. Selection 8 this time
p2
2 on log
8.8.8.8 for ntp
I think that’s it.
Do you have anything chosen in AI-Protection under dns filtering or parental controls? Not positive they work with each other. Try Google anycast its selection I think 53 or 58...
Nothing in ai. I have to reset to defaults every time I try, to get online to download script. So, very vanilla
Tried #58. NTP still not updating
Trying now.
Still not working.
Going off memory:
Install dnscript
No ipv6
p2
2 on log
8.8.8.8 for ntp
I think that’s it.
Since when is 8.8.8.8 an NTP server? Try pool.ntp.org
I worded that poorly.
In this section of the install, I left it as default(8.8.8.8):
 Info:  Set a DNS server for initializing dnscrypt-proxy
 Info:  and router services (e.g. ntp) at boot
 =>  Default is 8.8.8.8:
Can you post the contents of /jffs/dnscrypt/dnscrypt.toml please?
Also what does the below return?
pidof dnscrypt-proxy
This is all BEFORE a reboot, as I can't get online after:
#        dnscrypt-proxy configuration        #
## This is an example configuration file.
## You should adjust it to your needs, and save it as "dnscrypt-proxy.toml"
## Online documentation is available here: https://dnscrypt.info/doc
#         Global settings        #
cert_ignore_timestamp = true
## List of servers to use
## If this line is commented, all registered servers matching the require_* filters
## will be used
## The proxy will automatically pick the fastest, working servers from the list.
## Remove the leading # first to enable this; lines starting with # are ignored.
server_names = ['google']
## List of local addresses and ports to listen to. Can be IPv4 and/or IPv6.
## To only use systemd activation sockets, use an empty set: []
listen_addresses = ['127.0.0.1:65053']
## Maximum number of simultaneous client connections to accept
max_clients = 250
## Require servers (from static + remote sources) to satisfy specific properties
# Use servers reachable over IPv4
ipv4_servers = true
# Use servers reachable over IPv6 -- Do not enable if you don't have IPv6 connectivity
ipv6_servers = false
# Use servers implementing the DNSCrypt protocol
dnscrypt_servers = true
# Use servers implementing the DNS-over-HTTPS protocol
doh_servers = true
## Require servers defined by remote sources to satisfy specific properties
# Server must support DNS security extensions (DNSSEC)
require_dnssec = false
# Server must not log user queries (declarative)
require_nolog = false
# Server must not enforce its own blacklist (for parental control, ads blocking...)
require_nofilter = false
## Always use TCP to connect to upstream servers
force_tcp = false
## How long a DNS query will wait for a response, in milliseconds
timeout = 2500
## Load-balancing strategy: 'p2' (default), 'ph', 'fastest' or 'random'
lb_strategy = 'p2'
## Log level (0-6, default: 2 - 0 is very verbose, 6 only contains fatal errors)
log_level = 2
## log file for the application
# log_file = 'dnscrypt-proxy.log'
## Use the system logger (syslog on Unix, Event Log on Windows)
# use_syslog = true
## Delay, in minutes, after which certificates are reloaded
cert_refresh_delay = 240
## Fallback resolver
## This is a normal, non-encrypted DNS resolver, that will be only used
## for one-shot queries when retrieving the initial resolvers list, and
## only if the system DNS configuration doesn't work.
## No user application queries will ever be leaked through this resolver,
## and it will not be used after IP addresses of resolvers URLs have been found.
## It will never be used if lists have already been cached, and if stamps
## don't include host names without IP addresses.
## It will not be used if the configured system DNS works.
## A resolver supporting DNSSEC is recommended. This may become mandatory.
fallback_resolver = '8.8.8.8:53'
## Never try to use the system DNS settings; unconditionally use the
## fallback resolver.
ignore_system_dns = true
#        Filters        #
## Immediately respond to IPv6-related queries with an empty response
## This makes things faster when there is no IPv6 connectivity, but can
## also cause reliability issues with some stub resolvers. In
## particular, enabling this on macOS is not recommended.
block_ipv6 = false
#        Route queries for specific domains to a dedicated set of servers        #
## Example map entries (one entry per line):
## example.com 9.9.9.9
## example.net 9.9.9.9,8.8.8.8
# forwarding_rules = 'forwarding-rules.txt'
#        Cloaking rules       #
## Cloaking returns a predefined address for a specific name.
## In addition to acting as a HOSTS file, it can also return the IP address
## of a different name. It will also do CNAME flattening.
## example.com     10.1.1.1
## www.google.com  forcesafesearch.google.com
# cloaking_rules = 'cloaking-rules.txt'
#        DNS cache        #
## Enable a DNS cache to reduce latency and outgoing traffic
cache = false
## Cache size
cache_size = 256
## Minimum TTL for cached entries
cache_min_ttl = 600
## Maxmimum TTL for cached entries
cache_max_ttl = 86400
## TTL for negatively cached entries
cache_neg_ttl = 60
#        Query logging        #
## Log client queries to a file
[query_log]
  ## Path to the query log file (absolute, or relative to the same directory as the executable file)
  # file = 'query.log'
  ## Query log format (currently supported: tsv and ltsv)
  format = 'tsv'
  ## Do not log these query types, to reduce verbosity. Keep empty to log everything.
  # ignored_qtypes = ['DNSKEY', 'NS']
#        Suspicious queries logging        #
## Log queries for nonexistent zones
## These queries can reveal the presence of malware, broken/obsolete applications,
## and devices signaling their presence to 3rd parties.
[nx_log]
  # file = 'nx.log'
  format = 'tsv'
#        Pattern-based blocking (blacklists)        #
## Blacklists are made of one pattern per line. Example of valid patterns:
##   example.com
##   *sex*
##   ads.*
##   ads*.example.*
##   ads*.example[0-9]*.com
## Example blacklist files can be found at https://download.dnscrypt.info/blacklists/
## A script to build blacklists from public feeds can be found in the
## `utils/generate-domains-blacklists` directory of the dnscrypt-proxy source code.
[blacklist]
  ## Path to the file of blocking rules (absolute, or relative to the same directory as the executable file)
  # blacklist_file = 'blacklist.txt'
  ## Optional path to a file logging blocked queries
  # log_file = 'blocked.log'
  ## Optional log format: tsv or ltsv (default: tsv)
  # log_format = 'tsv'
#        Pattern-based IP blocking (IP blacklists)        #
## IP blacklists are made of one pattern per line. Example of valid patterns:
##   127.*
##   fe80:abcd:*
##   192.168.1.4
[ip_blacklist]
  # blacklist_file = 'ip-blacklist.txt'
  # log_file = 'ip-blocked.log'
#        Time access restrictions        #
## One or more weekly schedules can be defined here.
## Patterns in the name-based blocklist can optionally be followed with @schedule_name
## to apply the pattern 'schedule_name' only when it matches a time range of that schedule.
## For example, the following rule in a blacklist file:
## *.youtube.* @time-to-sleep
## would block access to Youtube only during the days, and period of the days
## define by the 'time-to-sleep' schedule.
## {after='21:00', before= '7:00'} matches 0:00-7:00 and 21:00-0:00
## {after= '9:00', before='18:00'} matches 9:00-18:00
[schedules]
  # [schedules.'time-to-sleep']
  # mon = [{after='21:00', before='7:00'}]
  # tue = [{after='21:00', before='7:00'}]
  # wed = [{after='21:00', before='7:00'}]
  # thu = [{after='21:00', before='7:00'}]
  # fri = [{after='23:00', before='7:00'}]
  # sat = [{after='23:00', before='7:00'}]
  # sun = [{after='21:00', before='7:00'}]
  # [schedules.'work']
  # mon = [{after='9:00', before='18:00'}]
  # tue = [{after='9:00', before='18:00'}]
  # wed = [{after='9:00', before='18:00'}]
  # thu = [{after='9:00', before='18:00'}]
  # fri = [{after='9:00', before='17:00'}]
[sources]
  ## An example of a remote source
  [sources.'public-resolvers']
  url = 'https://download.dnscrypt.info/resolvers-list/v2/public-resolvers.md'
  cache_file = 'public-resolvers.md'
  minisign_key = 'RWQf6LRCGA9i53mlYecO4IzT51TGPpvWucNSCh1CBM0QTaLn73Y7GFO3'
  refresh_delay = 72
  prefix = ''
  ## Another example source, with resolvers censoring some websites not approriate for children
  ## This is a subset of the `public-resolvers` list, so enabling both is useless
  #  [sources.'parental-control']
  #  url = 'https://download.dnscrypt.info/resolvers-list/v2/parental-control.md'
  #  cache_file = 'parental-control.md'
  #  minisign_key = 'RWQf6LRCGA9i53mlYecO4IzT51TGPpvWucNSCh1CBM0QTaLn73Y7GFO3'
## Optional, local, static list of additional servers
## Mostly useful for testing your own servers.
[static]
  # [static.'google']
  # stamp = 'sdns://AgUAAAAAAAAAACDyXGrcc5eNecJ8nomJCJ-q6eCLTEn6bHic0hWGUwYQaA5kbnMuZ29vZ2xlLmNvbQ0vZXhwZXJpbWVudGFs'
Reboot then run this from SSH
/jffs/dnscrypt/manager dnscrypt-start
Does syslog give any errors? All looks configured properly including fallback resolver
Server: 127.0.0.1
Address 1: 127.0.0.1 local.localdomain
nslookup: can’t resolve ‘pool.ntp.org’
Expected but at least it's using the router (or trying to). Is dnscrypt running?
Also, I've just found this on 1st page for further investigating:
How to report issue:
I need following directory and files:
/jffs/dnscrypt
/jffs/scripts/dnsmasq.postconf
/jffs/scripts/firewall-start
/jffs/scripts/wan-start
One can use this command to create a tar archive of these files:
echo .config > exclude-files; tar -cvf dnscrypt.tar -X exclude-files /jffs/dnscrypt /jffs/scripts/dnsmasq.postconf /jffs/scripts/firewall-start /jffs/scripts/wan-start ; rm exclude-files
in current directory and send me the archive for debug.
Thanks. Just created the tar file.
Tried running that command in windows cmd. ‘Pidof’ is not recognized...
I noticed this on page 1:
Current features:
- dnscrypt-proxy version 2 with DoH and DNSCrypt version 2 protocols, multiple resolvers, and other features
- Running as nobody through nonroot binary (using --user requires change to passwd)
- Support ARM and MIPSEL based routers
- Support OpenDNS dynamic IP update by entering your OpenDNS account information
- Handling ntp update at router boot up by starting dnscrypt-proxy with cert_ignore_timestamp option
- Redirect all DNS queries on your network to dnscrypt if user chooses to
- Install haveged/rngd for better speed with dnscrypt and other cryptographic applications
- Support various HW RNG such as TrueRNG (tested with v3), TrueRNGpro, OneRNG, EntropyKey
- Ability to setup a swap file
- Ability to setup timezone file (/etc/localtime) used by dnscrypt-proxy and other apps
- Ability to reconfigure dnscrypt-proxy without reinstalling unlike previous installer for dnscrypt-proxy version 1.x.x
Send it to you or bigeyes0x0?
OK, I also ran the cmd with Putty. It didn't return anything.
Send to me please since I'm online at the moment! Hm, no return means dnscrypt-proxy isn't running.
The "ignore timestamp" feature is set to true in your config, so I'm unsure why dnscrypt-proxy isn't running. Maybe increase the logging level of dnscrypt and try to start it manually with the below again? Happy for you to send me the whole syslog after you try running the command and I'll go through it.
