It’s an 86u.@Andy1932 which router do you have?
Right after installation before reboot, can you run these commands:It’s an 86u.
This is all that I see before a reboot:Right after installation before reboot, can you run these commands:
/jffs/dnscrypt/manager dnscrypt-start
pidof dnscrypt-proxy
Then send me the output of these commands as well as any log from dnscrypt-proxy in WebUI System Log.
admin: Start dnscrypt-proxy
Feb 13 19:10:23 admin: Start dnscrypt-proxy
Feb 13 19:10:41 ntp: start NTP update
Feb 13 19:11:01 ntp: start NTP update
Feb 13 19:11:21 ntp: start NTP update
Feb 13 19:11:41 ntp: start NTP update
Just ran the 1) install/Update option and still getting dnscrypt-proxy 2.0.3 at the moment.Script updated to install dnscrypt-proxy 2.0.5 as well as applying operation settings directly without reboot.
Is there any reason to not use dnscrypt's cache? Or does dnsmasq still cache so it's unnecessary overhead?
I have some clients that bypass dnsmasq for dns and go direct to dnscrypt (exempting them from AB-Solution filtering), so already running as root on 53 of an IP alias. Since I have that setup, I've enabled the cache, and made use of the cloaking rules for local domain names to still be resolvable. Many thanks for the script making this so simple!Few reasons:
- Running dnscrypt as standalone recursive and caching DNS server without dnsmasq as forwarder:
. It can only be run as root as you need to listen on port 53
. Without dnsmasq some internal domain names and router features will not work
- Running dnscrypt as recursive and caching DNS server with dnsmasq as forwarder: unnecessary overhead so it's better to leave dnsmasq with caching function anyway.
Yes that's fine, I write code and provide support for a living so I have my changes to your manager script documented and just need to merge them after each update.Your setup is exotic. To cover that I would need to include extra code with very little user base for it. I can only try to satisfy most of the users out there.
IMO, with the ability to use old config file after updating, your use case is not an issue at all. Just edit toml file as you like.
Works fine! Thanks!Issue with RT-AC86U should be fixed and dnscrypt-proxy is updated to 2.0.6.
Tag @Andy1932
Info: proceeding with your selection.
=> Please enter the number designates your selection, [1-2]: 1
Info: Downloading haveged
*** Error: Unable to download https://github.com/thuantran/dnscrypt-asuswrt-installer/raw/master/armv7/haveged
Info: init-start file already configured
Info: Operation completed. You can quit or continue
Info: manager is up to date. Skipping...
curl -L -k https://github.com/thuantran/dnscrypt-asuswrt-installer/raw/master/armv7/haveged -o /jffs/dnscrypt/haveged
% Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed
100 157 100 157 0 0 157 0 0:00:01 0:00:01 --:--:-- 107
Warning: Failed to create the file /jffs/dnscrypt/haveged: Text file busy
1 106k 1 1918 0 0 959 0 0:01:53 0:00:02 0:01:51 959
curl: (23) Failed writing body (0 != 1918)
Welcome To SNBForums
