I installed diversion on my RT-AX86U and it has replaced my freshtomato ad blocking script + Pihole with no noticable change in ads.
However, it has placed a entware/ folder on my sda2 drive which I use for both media streaming and a shared network drive for my home which I use every day for work. Anyone browsing files on a TV or when working on my pc, sees this entware folder that I would rather not exist (I have no other visible folders on the drive).
1) Can I remove entware now that diversion has been installed, or must this folder remain?
2) If it must stay can I hide it? I tried the steps here but it did not work, even after rebooting all devices.
( I only entered the line for entware and not skynet since I don't believe I have that. I did a chmod command (not sure which as it is not in that thread!) which turned the filename green but entware folder is still present).
SMB sharing and skynet/entware.
I sort of have a solution but I was trying to see if there was a more "elegant/proper" one. It seems the SMB server shares out all root folders found on a USB device plugged into the router. This means entware and skynet show up. I of course can restrict access to these folders but I would...
www.snbforums.com
