Download Master install problem - advice please
pixeler02
Hello,
I recently puchased a AC68U and installed merlin 378.55.
I'm having an issue when I click install for Download Master. When I select a disk it just says "The remote server is not responding."
How do I fix this? Any help appreciated, as I would like to install Download Master.
Thank you!
I am betting you did not do a reset to factory defaults after flashing the new firmware?
Do so now and manually and minimally configure the router to connect to your ISP and secure the router.
I am pretty sure Download Master is not used anymore.
Thanks for the reply!
I did follow the advice and reset to factory defaults after flashing new firmware, then set everything up from scratch. Although I will back up my settings and try this again, and report back, just in case.
Is there a reason Download Master is not used anymore? It's mentioned in the changelog as recently as 378.50 Beta 1 (25-Jan-2015). (Does something else take its place?) Cheers.
Sorry, don't use it at all. I think there is another called Transmission?
Hope someone else comes to help.
Glad to say that resetting to factory with minimal config, has overcome the difficulty installing Download Master. Have a great day.
I haven't looked at Downloadmaster in over a year, but at the time I was advising against using it for the following reasons:
1) Based on an outdated version of Transmission
2) Came with aMule, with no way to fully disable it - so it was sharing your USB disk by default to the whole world
3) Running a torrent client on a low-power device such as a router tends to negatively impact your router's performance and stability
