dropbear-offenders (bans ip that try and access ssh without proper credentials)
Is there anyway to have this script also search for these entries and place their ips in the blacklist offenders file:
Mar 24 20:11:32 dropbear[21211]: Login attempt for nonexistent user from 162.144.102.19:59860
I got ssh password login disabled so the only entries I see are like the above, but it appears this script is tailored to look for bad password attempts.
I saved "S81dropbear-offenders" to /opt/etc/init.d/.
where to save "dropbear_offenders" file?
if i set use_whitelist_lan="enabled", my local ips are whitelisted automatically by script? or i should make it manually.
I look into contents of ur script but I couldn't understand most of linux scripts.
If I make an empty file by "touch /jffs/offenders.whitelist", my local ip/cidr is processed by ur script automatically?
sorry for many question. I'm a linux novice.
required step by step tutorial.
where to save files?
