dsl ac68 u any good?
Select an app that you like the look of/based on the user ratings in your mobile store - they all do the same thing so its user preference?
Then use Better Search (and/or your internet search engine of choice) to find articles about wifi channels so you can interpret your results and decide if they need to be changed/test.
@userlee5267 Best Wi-Fi coverage 'app'? None of them. Do not install. Do not give your firstborn away. Do not waste time with the guessing games and assumptions they make on your network - while effectively ignoring all non-Wi-Fi interference and Wi-Fi utilization too within your environment.
If you must use a utility, then Helge Keck (helge-keck.com) which offers WinFi for Windows users is what I would suggest. Still don't recommend using it to set anything up if time is limited, but it is good for the curious to see what is going on in the airways around them.
Control Channel Setup 2021
