Hi, I have had a ASUS DSL-AC68U for about 2 years now on ADSL, and VDSL has become available in my area so i switches about a month ago.
While on ADSL i had adaptive QoS running nicely and also traffic Analyzer. Also DNS was set on the WAN side, and there was no DNS set on the LAN side, so simply using the DNS masq i have been reading about. The firmware upgrade/check for newer firmware also worked well.
When i switched from ADSL to VDSL, had some issues and reset to defaults with the factory reset and started fresh. I was running firmware version 3.0.0.4.380_7712, reset to default, stayed on the same firmware.
Since i reset to default, and got connected to VDSL, DNS has never worked. As in put the dns under the WAN settings, and the router can not resolve the time server or complete any nslookups. Also i have to set the DNS server on the LAN or my clients can not resolve names when the dns server is the router via DHCP.
It seems like DNS is not running.
I also can not get traffic Analyzer working either. This was working before too (i am thinking it maybe because dns isnt working, it cant get an NTP update, but just a thaught).
So i rolled back the firmware the other night to see if it made a difference, but it didnt. I did erase nvram after the roll back last night (mtd-erase2 nvram)
I am now running firmware 3.0.0.4.380_4026-g24cd33e
Ultimately i would like to get back to the newer firmware, but mostly i would like to to work properly with dns pointing o the router and the router caching the DNS results and traffic analyzer working again.
With out DNS working, it also cant check for newer firmware versions.
Here is what happens when i try to make the router complete an nslookup
Any ideas on how to help figure this out?
Been googling the sh!t out of this, but doesn't exactly look like a common issue.
Let me know if more config details are required.
