CONFIGURATION
PROBLEM
I have a problem with apparently random and intermittent Internet disconnects, resulting in pauses of a few seconds or outages of several hours. This the Hub/modem disconnecting, not the router. I have not noticed any occasions when the router has become disconnected from the HH1000. The modem connection may be stable for a few days or there may be several disconnects an hour. These disconnects started in April this year. Typically, during disconnects, there are multiple PPPoE timeout errors. I have seen several hours of these error messages in the HH1000 System Log; once every couple of seconds. Before the problem started in April, the connection had been running for about a year with no apparent problems.
A visiting Bell tech claimed that Asus routers don't work well with the HH1000. He didn't solve the problem.
I noted the advice about using Cat5e or Cat 6 cable in another recent post, but I think that this likely would only affect router to Hub (router) connections and not Hub (modem) to ISP connections.
I don't see how the N66U can cause the modem to disconnect in this configuration. Am I correct?
Thank you
Gordon
- ISP: Bell Canada DSL Business Internet (Fibe Internet 10)
- Hub: Bell Home Hub 1000 (Sagemcom F@st 4350). The problems originally started while using an old Speedstream modem, which was replaced by Bell Canada with the HH1000.
- Second router: Asus RT-N66U. Firmware is Merlin:378.54_2.
- The HH1000 is operating in Normal (not Bridge) mode, so it uses both the modem and router functions of the Hub. The WAN port of the N66U is connected to one of the HH1000 LAN ports. The HH1000 DHCP server is running and the N66U is set to Autoconnect (not PPPoE).
PROBLEM
Thank you
Gordon
