DUAL WAN Failover version v2.1.2 and router RT-AX88U_PRO
dexu
I have a problem with version v2.1.2 and router RT-AX88U_PRO After a few hours the WAN0 link starts to float. Pings increase and the logs show the message:
Oct  4 09:46:25 wan-failover: Packet Loss Detected - WAN0 Packet Loss: 33%
Oct  4 09:46:32 wan-failover: Packet Loss Detected - WAN0 Packet Loss: 33%
Oct  4 09:46:47 wan-failover: Packet Loss Detected - WAN0 Packet Loss: 33%
Oct  4 09:49:56 wan-failover: Ping Time Above Maximum Threshold: 80ms - WAN0 Ping Time: 89ms
Oct  4 09:49:59 wan-failover: Ping Time Below Maximum Threshold: 80ms - WAN0 Ping Time: 14ms
Oct  4 09:50:13 wan-failover: Ping Time Above Maximum Threshold: 80ms - WAN0 Ping Time: 203ms
Oct  4 09:50:16 wan-failover: Ping Time Below Maximum Threshold: 80ms - WAN0 Ping Time: 49ms
Oct  4 09:53:07 wan-failover: Ping Time Above Maximum Threshold: 80ms - WAN0 Ping Time: 80ms
Oct  4 09:53:07 wan-failover: Packet Loss Detected - WAN0 Packet Loss: 33%
Oct  4 09:53:10 wan-failover: Ping Time Below Maximum Threshold: 80ms - WAN0 Ping Time: 70ms
Oct  4 09:54:19 wan-failover: Packet Loss Detected - WAN0 Packet Loss: 33%
Oct  4 09:56:22 wan-failover: Ping Time Above Maximum Threshold: 80ms - WAN0 Ping Time: 114ms
Oct  4 09:56:26 wan-failover: Ping Time Below Maximum Threshold: 80ms - WAN0 Ping Time: 14ms
When the same link is connected as WAN1, I disconnect the second cable then .. It works as it should. Is it time to buy MIKROTIK in its place to support 2x WAN? :)
Both links are connected to ETHERNET. One static IP address, the other wan is the address obtained from DHCP.
Best Regards, Marcin.
