Dodge DeBoulet
After struggling with connectivity issues requiring weekly reboots of my RBK963, I've given up. This 6/6E solution is hot garbage, and the only way I've been able to get any semblance of stability is to replace its routing/DNS/DHCP functionality with an OPNSense-based firewall and a Pihole and turn it into an access point. Even then I have to reboot it every 3-4 weeks to get some devices to reconnect. I have a 22 page log of the support incident with NetGear and my patience is way beyond exhausted. I will very likely be obtaining a refund from either the reseller or NetGear (my state has an implied warranty law that makes most limited warranty restrictions irrelevant).
I should also mention that I found the Orbi's configurability far too simplistic for my needs; no separate 2.4/5GHz access points (other than the IoT network, which is not isolated from the "main" network), opaque firewall, aggravating port forwarding configuration, painfully slow and inconvenient DHCP address reservation setup ... I could go on.
So ... I'm extremely happy with the "new" firewall (it's actually an older Dell SFF PC with a dual-port GigE NIC); rock-solid stable, highly configurable, and actually lets me see who's banging on my WAN NIC. And the Pihole offers a cleaner and more convenient mechanism for managing DHCP reservations (never mind the excellent ad/malware filtering). I intend to keep both as I move forward with a mesh wifi replacement, and this means that I don't need a wifi router.
I have a large house (4000+ square feet), with 3 locations that need both wifi and wired support. One is central, the other two at opposite ends of the house. I'm looking for an AP solution that offers a dedicated wireless backhaul, with connectivity for wired devices at the satellite locations. While one of the satellite locations is potentially suitable for a wired backhaul, the other is not (at least without a very expensive cable run).
I have 6E devices on my network so support for that is desirable. I would also like the option to configure distinct 2.4GHz and 5GHz VAPs. I am not at all averse to considering "professional/commercial" level solutions; I spent $1500 on this NetGear mess and figure I'll have at least that much to spend on its replacement.
If you've read this far, I admire and appreciate your commitment Thanks in advance for any recommendations/advice!
EDIT:
A few more details ... I have approximately 40 wireless devices and another 20 or so wired devices. Approximately 2/3 of the wireless devices are IoT; thermostats, switches, plugs, webcams and appliances, including Four 4K-capable media consumption devices (those are pretty much all wired but 2 of them would require connectivity via a wireless backhaul); 3 of the 4K devices are often in use simultaneously.
Our current ISP subscription is 300/10 but we commonly get 350/12 and are considering an upgrade to 900/20. That's not really an issue for AP selection, although I would prefer the AP "hub" support at least 2.5Gb/s ethernet.
The house is on a very private, geographically isolated 7 acre plot, so no interference to worry about from neighboring wifi APs/routers.
EDIT:
