EA9500 Serial Console to CFE
Hi, I tried to disassemble the router with your guide, but after I removed the 4 bottom screws, I don't seem to be able to pry open the top cover. Did you use a lot of force to try to open it? Or am I doing it wrong?
I made this thread a long time ago - can't remember. I can check on that later today.
I put mine back together and the top popped right off. I knew that was too easy and then remembered that when I first pulled the top off I broke some of the clip tabs.
I doubt you will be able to remove it without breaking a few tabs.
RatherLoopy Linksys EA9500 - Local DNS General Wi-Fi Discussion 5
