Entware-arm - synced with Entware (mips) 2015.09
hubicuse was deleted as broken from all entware feeds in July - https://github.com/Entware/entware/wiki/Changelog
You can try to install the archived version found in archive - http://qnapware.zyxmon.org/binaries-armv7/archive/
I tried installing any archived version of any program and it would just download the latest version immediately after downloading the archived version. I used the command opkg install http://link-to-the-archived-version.ipk . I tried with the -force-downgrade flag which didn't work so I wasn't sure how to force the installation of an older version.
devnulldne Download and install from local file system:
root@ws880:/tmp/home/root# wget http://qnapware.zyxmon.org/binaries-armv7/archive/lftp_4.6.0-1_armv7soft.ipk
--2015-09-26 07:23:22--  http://qnapware.zyxmon.org/binaries-armv7/archive/lftp_4.6.0-1_armv7soft.ipk
Resolving qnapware.zyxmon.org... 81.4.123.217
Connecting to qnapware.zyxmon.org|81.4.123.217|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 409569 (400K) [text/plain]
Saving to: 'lftp_4.6.0-1_armv7soft.ipk'
lftp_4.6.0-1_armv7soft.ipk      100%[=======================================================>] 399.97K  1006KB/s   in 0.4s
2015-09-26 07:23:23 (1006 KB/s) - 'lftp_4.6.0-1_armv7soft.ipk' saved [409569/409569]
root@ws880:/tmp/home/root# opkg install ./lftp_4.6.0-1_armv7soft.ipk
Installing lftp (4.6.0-1) to root...
Configuring lftp.
root@ws880:/tmp/home/root# rm lftp_4.6.0-1_armv7soft.ipk
Entware.arm is synchronized with Entware (mipsel version).
The list of changes is here - https://github.com/Entware/entware/wiki/Changelog (September 2015)
The differences with Entware (mipsel):
ffmpeg is updated to 2.8;
minidlna is updated to 1.1.5. It includes new patches for custom icon, thumbnail generation, fast rescan and a fix for some LG TV's;
logrotate is updated to 3.9.1 - now the admin user (root) is supported!
deluge is updated to 1.3.12.
Please report bugs at github or here. Please give information on you model/architecture when you report bugs!!!
Minidlna doesn't start at boot. Here's log:
Oct  2 13:50:21 custom script: Running /jffs/scripts/post-mount (args: /tmp/mnt/ExternalUSB)
Oct  2 13:50:21 kernel: Adding 524284k swap on /opt/swap.  Priority:-1 extents:3 across:540668k
Oct  2 13:50:44 crond[474]: time disparity of 395210 minutes detected
Oct  2 13:52:21 admin: Started minidlna from .
Oct  2 13:52:22 admin: Started ipset-dns from .
Oct  2 13:52:22 rc_service: hotplug 1032:notify_rc restart_nasapps
Oct  2 13:52:22 iTunes: daemon is stopped
Oct  2 13:52:22 FTP Server: daemon is stopped
Oct  2 13:52:23 Samba Server: smb daemon is stopped
Oct  2 13:52:23 kernel: gro disabled
Oct  2 13:52:23 Timemachine: daemon is stopped
Oct  2 13:52:23 kernel: gro enabled with interval 2
Oct  2 13:52:24 Samba Server: daemon is started
/jffs/scripts/post-mount:
#!/bin/sh
if [ $1 = "/tmp/mnt/ExternalUSB" ]
then
  ln -nsf $1/entware.arm /tmp/opt
  swapon /opt/swap
  sleep 60
  /opt/etc/init.d/rc.unslung restart
fi
After that ipset-dns is started, but minidlna is not. Second try via «/opt/etc/init.d/rc.unslug start» will start
minidlna properly. What I'm doing wrong?
Using username "admin".
Authenticating with public key "rsa-key-20140714"
ASUSWRT-Merlin WS880_3.0.0.4 Wed Aug 19 15:27:59 UTC 2015
admin@WS880-6F2E:/tmp/home/root# htop
admin@WS880-6F2E:/tmp/home/root# /opt/etc/init.d/rc.unslung check
Checking ipset-dns...              alive.
Checking minidlna...              dead.
admin@WS880-6F2E:/tmp/home/root# /opt/etc/init.d/rc.unslung start
Starting ipset-dns...              already running.
Starting minidlna...              done.
/opt/var/minidlna/minidlna.log
Seems to me minidlna is shutting down because of rc_service. here is log:
Oct  2 16:41:01 custom script: Running /jffs/scripts/post-mount (args: /tmp/mnt/ExternalUSB)
Oct  2 16:41:01 rc_service: ntp 466:notify_rc restart_diskmon
Oct  2 16:41:01 disk_monitor: Finish
Oct  2 16:41:02 disk monitor: be idle
Oct  2 16:41:02 kernel: Adding 524284k swap on /opt/swap.  Priority:-1 extents:3 across:540668k
Oct  2 16:41:12 admin: Started /opt/etc/init.d/rc.unslung restart.
Oct  2 16:41:12 admin:  minidlna -f /opt/etc/minidlna.conf
Oct  2 16:41:12 admin: Started minidlna from .
Oct  2 16:46:12 admin:  ipset-dns Win10tracking Win10tracking 1919 8.8.8.8
Oct  2 16:46:12 admin: Started ipset-dns from .
At this point minidlna successfuly started and working. Than some strange shirt happens (right after /jffs/scripts/post_mount execution completes):
Oct  2 16:46:12 rc_service: hotplug 1074:notify_rc restart_nasapps
Oct  2 16:46:13 iTunes: daemon is stopped
Oct  2 16:46:13 FTP Server: daemon is stopped
Oct  2 16:46:14 Samba Server: smb daemon is stopped
Oct  2 16:46:14 kernel: gro disabled
Oct  2 16:46:15 Timemachine: daemon is stopped
Oct  2 16:46:15 kernel: gro enabled with interval 2
Oct  2 16:46:15 Samba Server: daemon is started
Minidlna log says:
[2015/10/02 13:46:12] minidlna.c:156: warn: received signal 15, good-bye
Needed to add some delay to S90minidlna starting script to be able to see logging, or else it was shutted down before any log was created:
#!/bin/sh
ENABLED=yes
PROCS=minidlna
ARGS="-f /opt/etc/minidlna.conf"
PREARGS=""
DESC=$PROCS
PATH=/opt/sbin:/opt/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
. /opt/etc/init.d/rc.func
sleep 300
PS: renaming binary to megadlna :) (with corresponding scripts) resolves problem, rc_service stops it no more. Minidlna in nasapps list?
I am using tomato now. minidlna was probably stopped by the system - since dlna server is not enabled by firmware?
Yes, internal ASUS dlna server is not enabled in GUI. But if I will enable it, will not it conflict with entware minidlna?
