dave14305
Part of the Furniture
Did you ever change the Log level settings on the Syslog page?this is the only messages since my reboot, apparently the script didn't run
@dave14305 actually yes, I just changed it now to DEBUG and ALL then I noticed in the syslog file that Entware is not present on my disk mounted (MERLIN_1) although I installed it on that disk with the amtm i option ep. Actually on my disk, there is the folder entware but it is empty ! I don't understand why.... can you help ?Did you ever change the Log level settings on the Syslog page?
May 5 07:06:01 Entware: (Notice) /tmp/mnt/MERLIN_1 does not contain Entware, skipping device
You can likely remove that script after the asusware folder is removed from the device.@dave14305 Finally I have found something interessant with the post :
dn-vnstat fails when more than 1 USB drive attached
Because I have 2 USB drives...
So I've created the check-usb script and add it to post-mount script then I delete the asusware .arm directory and this solve my problem.
I hope this could be fix into next version of merlin ?
Maybe this helps
Welcome To SNBForums
