Solved ethtool question regarding at boot
DJones
So I want to use the command 'ethtool -A eth1 rx on tx on' for flow control "Advertised pause frame use:" and was wondering if this will require a startup script during boot to make the command permanent.
I assume yes.
My only concern is ethtool -r eth1 returns "Cannot restart auto negotiation: Operation not supported" so I'm curious is it's actually applying. I assume it is by these details as Advertised pause frame use was No prior.
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 10
Transceiver: internal
Auto-negotiation: on
MDI-X: Unknown
Link detected: yes
Yes, any changes made by ethtool will be lost after a reboot.
Thanks, that's pretty much what I needed to know. Now to make a quick script.
