Are you recommending a full reset with default?
All kinds of files are found but to be non-executable.
I browsed the files and they were in fact shown as non-executable. Nothing I could do to make chmod instruction stick.If you ever flashed a recent Asus stock firmware, this is normal - they recently added code that makes all the /jffs/* files non-executable. That shouldn't be the case with my firmware however, unless they hid a copy of that code in a location that I've missed.
Also the dnsmasq format problem when converting to the new system you have. The conversion somehow loses the last digit of the static addresses.If you ever flashed a recent Asus stock firmware, this is normal - they recently added code that makes all the /jffs/* files non-executable. That shouldn't be the case with my firmware however, unless they hid a copy of that code in a location that I've missed.
EDIT: indeed, Asus added one in a recent AX88U GPL merge that I missed. Removed.
Yes 192.168.50.51 was changed to 192.168.50.5. When I had a look at the dnsmasq.conf file it showed the addresses with the last digit dropped so I had like 20 devices with only four IPs. I use 192.168.50.x, 192.168.50.2x, 192.168.50.3x, 192.168.50.4x, 192.168.50.5x.Can you give me an example IP? It was working properly for me.
UPDATE: My addresses only use 2 digits in the last octet.
I dirty flashed the build on my RT-AC5300, after a reboot there weren't any AI Mesh options on the network map page. flashing back to stock.
All the info is provided in the 1st post ...did u follow the instructions below?
For AiMesh support, during this test phase, you must manually enable it. To do so, log in over SSH, then run the following commands:
touch /jffs/.gomesh
reboot
After your router is done rebooting, the webui should now be AiMesh-aware.
Van Halen's "no brown M&M" clause. (Google it).
are you suggesting I trash my dressing room? ;P
i don't think i have a dhcp static list?not sure what that is? manually assigned?
- removed node successfully.
- factory reset node (I always do it by holding down the wps button and power on) and added it back successfully. clients connected to it successfully.
both my router and node are RT-AC5300s
router: 384.13_alpha1-g3070c0d611
node: 3.0.0.4.384_45717-gadd52a8
the main reason i was trying this out was to see if your firmware resolved my 2.4Ghz issue ( https://www.snbforums.com/threads/r...s-on-5ghz-cannot-see-devices-on-2-4ghz.54397/ ) but it doesn't look like it![]()
Welcome To SNBForums
