failed Download Master Installation
Olndo Pindaro
RT-ax86S Merlin 388.2.2 I started installatation of asus download master but a blackout interrupted the installation before to finish.
A restarted. GUI said "done" and "lauch download master now". following the errata screenshot...
How I can force reinstall?
Olindo
Can it be removed in the „USB Application“ tab in the router WebUI?
If not, the this bit of code resets everything:
if [ -L "/tmp/opt" ]; then
    rm -f /tmp/opt 2> /dev/null
    rm -f /opt 2> /dev/null
fi
if [ -d "$(nvram get apps_mounted_path)/$(nvram get apps_install_folder)" ]; then
    rm -rf "$(nvram get apps_mounted_path)/$(nvram get apps_install_folder)"
fi
nvram set apps_mounted_path=
nvram set apps_dev=
nvram set apps_state_autorun=
nvram set apps_state_enable=
nvram set apps_state_install=
nvram set apps_state_switch=
nvram commit
fi
fi
nvram set apps_dev=
nvram commit
launched. Set restarted... thanks a lot!
