System Error Message
Part of the Furniture
Unfortunately routerOS likes to connect networks together, its one of its strengths that allows it to work in complex network configurations and do things that ubiquiti would simply not allow. Even for different subnets you have to add the static routes to prevent inter communication. If you've isolated layer 2 some things may not see each other but it wont prevent communication.Thanks. That explained a lot about the VLANs configuration. However if they are in the different subnets, it will cut the communication between guest network and the chromecasts.
