As things go in a forum one can readily mix things up between multiple threads, especially when they're extended over many days, so I don't recall anything you've set on the Asus router to correspond with that of the Netgear. Items which may not work the same between them. If you continue to experience instability and want to quickly determine whether it's hardware or just configuration, you might have to back off of that quoted statement and try things just the Asus way, in case there's some incompatibility.And reconfigured the whole thing again. Same way I did before. And I won't change, because that's the way it was working with my R7800, and I expect no less with the RT.
Only basic stuffBarring power glitches your uptime should be indefinite. So long as you're not applying settings willy-nilly in any case.
Well, change of the network range, a cloned MAC Address, same DHCP configuration, same SSID & password, ... I think that's all.As things go in a forum one can readily mix things up between multiple threads, especially when they're extended over many days, so I don't recall anything you've set on the Asus router to correspond with that of the Netgear.
Is there an Asus way when we're talking network configuration ?Items which may not work the same between them. If you continue to experience instability and want to quickly determine whether it's hardware or just configuration, you might have to back off of that quoted statement and try things just the Asus way, in case there's some incompatibility.
I don't remember seeing this on any Asus router. Settings requiring reboot warn about this and do it automatically. You don't have to reboot the router manually. There is no further "Applying setting" after the reboot unless it's something new in Pro firmware. I don't have a Pro series router to test with.
Well I do confirm what I said. I logged in the router just to check the GUI. And I clicked on Reboot instead of Logout out (the buttons are too close and I was thinking about something else). And guess what : I got the Applying settings. I didn't change anything at all.
Not a big deal, mind you![]()
I don't think I have a problem with my new router, it was the same thing with the previous one running the same firmware. I think it's the way it works now. And it's not a problem, just an another step when you reboot.If you don't get any confirmation here from other users of your model, you might have a problem there to be solved.
OE
Was it on Pro firmware? This is something new.
I sent back my RT-AX88U Pro and received the same model Monday. It's running the Asus firmware : 3.0.0.6.102_21514-g9affda2_136-g5d23cWas it on Pro firmware? This is something new.
I trust your memory over mine.
what's your average temperature ?
85°C if I'm correct
Thanx for your thoughts
My temperature is around 36.7C most of the time.
But it's not too good to run it at high temperatures, right ? Not that 55°C is high of course, but...Built-in thermal protection shuts down cores at 100C.
Luckily it's not noisy so... In the summer, it helps a lot to cool it down.You're welcome. Remove the fan under the router, not needed.
You missed his sarcasm. That's human body temperature.That low without a fan to cool it ?? Mine is around 56°C when idle, so 20°C more than yours.
That's not high, it's "comfortable". That's actually lower than any of my Asus routers that have been running for years. You're imagining a problem that doesn't exist.But it's not too good to run it at high temperatures, right ? Not that 55°C is high of course, but...
Welcome To SNBForums
