Few questions about Asus RT-AX88U pro
Thank you for your replies Mr @ColinTaylor and Mr @glens , now it's all clear :)
I had a question before, didn't get an answer. Just to make sure. I upgraded the Asus firmware that I installed when I got my RT ( 3.0.0.6.102_21514-g9affda2_136-g5d23c ) with a full reset factory before and after. Then I configured the router the way I need it on my LAN.
Now the firmware is :
I know you posted earlier in this thread : 3.0.0.6.102_32843-gad71435_295-g45475
Upgrading from a supplied stock firmware to the current version of stock firmware doesn't usually require a reset. This is a normal firmware update procedure. You would only do a reset if there was a significant jump in versions (e.g. from 3.0.0.4.388.x to 3.0.0.6.102.x) or after installing a custom firmware. What firmware version were you previously on? It should be printed on the case label.
Just want to make sure that the upgrade I did doesn't require a reset :)
