AntonK
Yes, that's how I switched modes. I'll try as you suggest. Thanks!
Wohoo, that did the trick.If you switched your AX86U from Router to AP Mode without touching anything else, the default configuration is Automatic IP. Reboot the router and run the Device Discovery tool once again. The router in AP Mode will take an IP from Firewalla's DHCP server. Use this IP to access the router's GUI.
Thanks Tech9!
